    [Plugin] Extrude Edges by Rails by Face
    82 Posts 25 Posters 229.3k Views 25 Watching
    • BoxB Offline
      Just divide the straight lines into a few segments and weld them back together, then they will be seen as a 'curve'.
        Sparda
        @Box
        Ah. that method worked.
        I didn't think of that method where I can weld the straight line after being divided.
        that was the last method I missed when I was having trouble with how to use the tool.
        Thank you for helping me out and that solved my problem.
        EDIT 1:
        Imgur (imgur.com)
        what Black arrows are pointing at is the rails (the straight lines) not being at the correct angle (referring to red line)
        Is there a way I can fix this?
        • 5 / 5
