    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Cement
    21 Posts 6 Posters 1.5k Views 6 Watching
    • david57D Offline
      david57
      Here's a quick model, lacking detail. I get impatient. Far from finished.
        ScottPara
        Tough to tell what this is. Yes, its cement but other than that I have no idea. Due to the DOF it makes the structure look miniature.
        What is this supposed to be?
        What render engine are you using.
        Being impatient can be a killer. Don't rush and expect great results. Many of the great renders you see take a great deal of time. Just setting up lighting and materials can take more time than the modeling itself.
        Scott
        Love the fact that some HATE my avatar.....
        • david57D Offline
          david57
          I was trying to make a building. It was rendered
          with blender 2.5 and took about 7.5 minutes to
          render on a single core laptop.
          Yes, You have to be very patient setting up your
          materials, lighting, grass, trees and things like
          this. It can take months to set them all up.
          After you have every thing ready you dont know
          what to render. πŸ˜„
            Cyberdactyl
            David, you may have intentionally wanted those main columns and the radius of the upper "roof" area faceted. But if you didn't, what you need to do is increase the circle segments and arc segments. To do that; as soon as you pick the circle command, type in something like 36. You'll notice the default is 12. You'll see it in the lower right corner beside "SIDES". Same with the arc command, put in something like 36.
            • david57D Offline
              david57
              Scale of this building is way-off.
              Doing lots of guess work.
              Yes, its Bulletproof.
              • david57D Offline
                david57
                Thanks. Yup, I know the trick, just type a number like 70S with the S at the end.
                • olisheaO Offline
                  olishea
                  dude it would make more sense if you started with a site and a use for the building. otherwise it'll never make sense.
                  you don't need to type 'S'. just the number works.
                  oli
                  • david57D Offline
                    david57
                    Ok, im not sure exactly how to do that. Do i have to create the
                    site first? Site is trees, terrain, foundations?
                    What came first? The chicken or the egg?
                    Im lost. You guys have the training.
                    Does every body do it this way?
                      tomsdesk
                      For my 2cents I'll say: "Just keep playing!"...you're obviously on the right track if you can muster such picky helpful suggestions. IMO the architecture fits the flat site quite nicely, but the grass want to be broken up a bit...or more. (And I too am a bit bothered by the column faceting 'cause I'm not convinced by the rest of the detailing that it was intentional.) Overall, though, I'm interested to see what you do next with this project!
                      (My only real gripe is the misuse of the word cement...which is only one of the materials used to make concrete :`)
                      2.5D Trees & Shrubs!
                      • olisheaO Offline
                        olishea
                        why not choose a real site near where you live?
                        you need a brief, a client. what would this person need? whats the purpose of the building? how does it relate to its context? surrounding buildings? topography?
                        this is how we learn.....an imaginary brief and an imaginary client but applied to a real site. you cannot just design a building in isolation. it must have meaning and purpose otherwise it just becomes a series of volumes. could be very pretty volumes, but meaningless all the same.
                        oli
                          tomsdesk
                          Oli, I agree whole-heartedly...and I also don't: depends on where the student is and where they're heading. (Both changing each minute and over time.) Bottomline...all the advice given here so far is excelent! (including mine, I think, to keep having fun at all costs when trying to learn whatever it is you want to learn :`) It just wants to be sifted through and used as needed, when it is meaningful, so as not to let it overwhelm or bog the process down.
                          • david57D Offline
                            david57
                            An update. I havnt done much to the model.
                            I smoothed the surface of the building.
                            On the grass i have to figure out how to break it up.
                            I did put brown patches on it.
                            I have to work on the glass and make it
                            arch. It looks to flat and to far in.
                              tomsdesk
                              David, the smoothing looks great...and I think the brown patches help (and are not quite repetitive yet). Several ways to break up the grass might work, like some "weeds" and such, or my fav: some kid's yard leavings. Or one thing I do often is to add something off-image to cast a shadow: a tree, another building, or even a cloud shaped object floating above...?
                              • david57D Offline
                                david57
                                Alright, Tom. Ill see what i can do.
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  I like the texture you are using for grass, but the 3 point perspective doesn't do it for me. Is the dark green yard part of the background image above the SU horizon? Did you create it or did you find an image that came that way?
                                  • olisheaO Offline
                                    olishea
                                    yeah its fair enough but you won't actually learn anything if you start going down the wrong path. well......you will learn how to go about things the wrong way.
                                    I think you will find by starting with a site/context it will inform the beginnings of the design process. otherwise it's like starting with a blank canvas and no direction. and start small, try articulating a small shelter (yes i have already seen the bus shelter thing you made a while back)...but something relating to context...not just plonked there.
                                    oli
                                      ScottPara
                                      I am with Oli. You will learn things by poking around and just trying different things but you will learn quicker and learn better practices learning from others and their recommendations. Many have been modeling and rendering for years and are more than willing to help but in the same sense you need to be willing to listen.
                                      If your purpose is to just make pretty pictures but not have a backing in architecture or design then you are on your way, If you want to establish a real design then there are a few issues:
                                      All structures are strongly affected by their surroundings/site and need to take those into account. So starting with the site is typically best. That being said the site itself needs some work:
                                      How will people get to this structure? There needs to be a path/road/driveway
                                      There needs to be some sort of roof drainage
                                      Are there any other window/doors. Currently it looks more like a vault in a pasture than a livable structure.
                                      The grass is nice but there needs to be more trees or at least some shrubs.
                                      It is a good start but still has a good way to go as well.
                                      Scott
                                        honoluludesktop
                                        Hmmm.... Wow, never even thought of doing something like that, is it a common technique to layer textures? Are the textures made transparent by SU, or do they have "alphaed" out holes?
                                        Davie, hope you had a nice flight:-)
                                        • david57D Offline
                                          david57
                                          @ honoluludesktop,
                                          The grass are hair particles and under this particles is a grass texture and under
                                          it is another one that looks light green and extends far to the horizon. The dark green in the horizon is called horizon color and settable in blender.
                                          Below is another render and maybe to many round corners. I tried to set
                                          a shadow on the grass but tree is to short and might have to stretch it.
                                          Flight will depart in 15 minutes.
                                          • david57D Offline
                                            david57
                                            @ honoluludesktop,
                                            Some of this textures were use in other scenes and
                                            I didnt remove them.
                                            @ Oli and Scott,
                                            Thanks for the advice and insight.
                                            I need to put this things in to practice.
                                            • 1 / 2
