    How to pass ISketchUpDocument from SU into c++
    5 Posts 3 Posters 950 Views 3 Watching
    • Z Offline
      zsacul
      I am working with SU sample plugin from TBD (many thanks for that).
      I have c++ dll with function:
      extern "C" int GetNum2(void * spApp)
      sketchup::ISketchUpDocument* pDoc = (sketchup::ISketchUpDocument*)spApp;
      return pDoc->IsValid();
      suddl.def:
      EXPORTS
      GetNum2
      In .rb file I have:
      mydll = path + "/SUDLL.dll"
      IleD = Win32API.new(mydll,"GetNum2",["P"],"I");
      UI.messagebox IleD.call(Sketchup.???)
      Is it possible to pass ISketchUpDocument pointer from Sketchup, to manipulate current view by c++ plugin?
      For example to write a c++ function that will move all points by Vector(10,0,0)?
        jhauswirth
        To get ISkpDocument from Ruby you can do-
        Sketchup.active_model.skpdoc
        But you can't modify the model from the SU C++ API.
        • Chris FullmerC Offline
          But you could do calculations inside C++ and send the results back to Ruby to then apply to the model, yeah?
          All my Plugins I've written
          • Z Offline
            zsacul
            Thanks for answer.
            Reading only would be fine.
            When I execute:
            UI.messagebox IleD.call Sketchup.active_model.skpdoc
            extern "C" int GetNum2(sketchup;;ISketchUpDocument*pDoc)
            it crashes, so I assume pDoc pointer is wrong.
            when I change it for
            return 2;
            it shows 2.
            Any ideas, what may be wrong?
            • Z Offline
              zsacul
              My fault, it is ISkpDocument*, not ISketchUpDocument*.
              Now it works!
              Thank you very much!
