    Render This: Interior
    78 Posts 25 Posters 18.9k Views 25 Watching
    • soloS Offline
      solo
      Jarynzlesa a new member here at SCF started a thread asking how he could make this scene look more realistic.
      http://img31.imageshack.us/img31/5651/schodyh.jpg
      So I thought I'd throw it out to y'all to tackle his model and render it 'realistic', the challenge here is that being a relative new SU user the model is not optimised, so the challenge is on you to take this model and either render as is or add to it. You cannot remove anything, you can rearrange, change views, textures etc.
      Open to all render solutions.
      Have fun.
      edit Plants have been removed, you can add your own.
      Model: http://www.box.net/shared/ooqghj5dmt
      (in SU6 format)
      http://www.solos-art.com
      • EarthMoverE Offline
        EarthMover
        I didn't see the original thread....what was this image rendered with? Must we keep the plant?
        Content Creator at Skapeup
        • soloS Offline
          solo
          Vray.
          I have removed the plants.
            CaptainsLS
            I threw one together, but of course Vue managed to mangle the light. The floor looks good but other than that everything else is a mess. I'll keep working on it.
              EarthMover
              Captain, are you welding your verts once you import into Vue? If not, that's most likely what's causing the light leaks.
                EarthMover
                Been a while Pete...needed a decent render challenge to get my mind off of "real work"!! Here's my shot at it using Vray for Max. Decided to go a little more "grungey" with it.
                Click for full res.
                  bytor
                  Adam,
                  Really nice image! Are you using the native sketchup file importer to get it to MAX? If so - have you had any issues with it?
                  Thanks,
                  Dean
                  Find the Cost of Freedom.....
                    CaptainsLS
                    Adam, I wish that was the answer; it would make for an easy fix. Verts were welded after import. (on your render) see where the light escapes from the above room at the top of the stairs? I believe that light is what appears on the corner...?
                      EarthMover
                      Not sure. I thoight the light above the stairs was from a space in that area. Pete may recognize an easy fix for the corner leaks. I have another one cooking in vray. Maybe ill give Vue a shot next. Did you try removing the window glass?
                        CaptainsLS
                        There is only glass on the back door, not the large window. I'll be curious to see what you or pete suggest.
                          EarthMover
                          Here's my second one. Decided to tone it down and do something more traditional. Minimal Post Processing on this one.
                          • soloS Offline
                            solo
                            That looks great Adam.
                            I hope by Wednesday next week to have a gap in my current project to play also.
                              markpyvi
                              Yes, looking good Adam. Definately should use a helmet sitting into the left armchair πŸ˜„ but thats not an issue at that case πŸ˜‰
                                bhbarchitects
                                Fancied a place by the sea.
                                Bike by alpine2.
                                vray and photoshop
                                  EarthMover
                                  Nice work Matthew. The exterior atmosphere is super convincing!
                                    bocian
                                    Noisy and too strong bump on the floor, but I do not have time for more.
                                    http://blogbezsensu.blogspot.com/
                                      EarthMover
                                      Captain,
                                      Here's a quick try with Vue. I rendered on Final, so there is still some blotchiness, but I think the feel is right. I used Image Based Lighting and an HDRI image to light the scene, but still using Global Radiosity. I also removed all fog and only minimal haze. There is still a little lighting issue in the far corner. I'm going to see if possible rounding that corner by a quarter inch or so might help to smooth it out.
                                      EDIT - Ran it again with the far inside corners rounded off a tad. Help to get rid of the hard lines between ceiling and walls, but still some minor light trapping issues. Also bumped render settings up to production a moved the sun position a tad.
                                      Raw Render
                                      Inside corners rounded, sun shifted a little and settings up'ed to production
                                        rcossoli
                                        Great works!!
                                        in the last image te wood from stairs is exellent.
                                        Is vray? or another software?
                                        THREEDIMENSIONSWEB dot COM
                                          bocian
                                          @rcossoli said:
                                          Great works!!
                                          Kerkythea
                                            D-space
                                            For Jarynzlesa πŸ˜‰
                                            http://blibestmentalt.no/54981
                                            • 1 / 4
