    [solved] rotating enitity toward target point
    3 Posts 2 Posters 360 Views 2 Watching
    • tbdT
      tbd
      can anyone help me in implementing a rotation around group center to face toward a target point ?
      EDIT:
      here is the solution code:
      def create_geometry(obj_origin)
        light = Sketchup.active_model.entities.add_group
        light.entities.add_circle(ORIGIN,Z_AXIS,10.cm,3)
        light.entities.add_line(ORIGIN,ORIGIN.offset(Z_AXIS,10.cm))
        t1 = Geom;;Transformation.translation(obj_origin - ORIGIN)
        Sketchup.active_model.entities.transform_entities(t1, light)
        # return light group
        light
      def rotate_geometry(grp, target)
        # quick access variables
        o = grp.bounds.center
        td = o - target
        axr = Z_AXIS * td
        anr = Z_AXIS.angle_between(td)
        # face the group toward this point
        Sketchup.active_model.entities.add_cpoint(target)
        t1 = Geom;;Transformation.rotation(o, axr, anr)
        grp.transform!(t1)
      grp = create_geometry(Geom;;Point3d.new(10,10,10))
      rotate_geometry(grp,Geom;;Point3d.new(20,20,20))
      SketchUp Ruby Consultant | Podium 1.x developer
      http://plugins.ro
      • J
        Jim
        To get the axis of rotation, take the cross product between the current direction (Vector) and the target direction(Vector).
        To get the angle of rotation, use the API method angle_between for the current and target vectors.
        Create a new rotation transformation and apply it.
        • tbdT
          tbd
          thanks Jim. just before your response I solved it in another way, using the axes of the target direction and creating a transformation array.
          wish I had asked this question 3 days ago πŸ˜‰
          http://plugins.ro
