    SketchUp-LightUp-Unity first try
    28 Posts 18 Posters 7.6k Views 18 Watching
    • O Offline
      OnlySean
      The best thing I learned while working with UNITY this summer was a simple workflow:
      SketchUp -> Blender -> UNITY
      u can leave out Blender for a static scenes, but the last time i checked, if u wanted movement or interaction, i.e: opening doors, u needed blender. Because all SketchUp Objects (groups) have the same origin (0,0,0) which made transforming or moving SketchUp geometry in UNITY a nightmare. I never found a function in UNITY that allowed to me reassign an objects origin to its center. Luckily all it takes in Blender is hitting to buttons once everything was selected. To figure out this workflow however, I spent 2 days Importing, Exporting and wildly swearing at my mac. If anyone has a better way pls let me know!
      format used from SU to Blend: .3ds
      format used from Blend to Unity: .blend
      • AnssiA Offline
        Anssi
        The problem of a plugin or standalone .exe solutions to display 3D content is that most clients are not very eager for things that require installing anything on their computer or running an unauthorized application. In most companies staff has no right to perform such operations, and would have to persuade an IT department to do the installation.
        Anssi
          Funny I have seen these Unity animation in another forum (6 jan 2010) without know who was the author!
          Sorry I have seen only the animation without click on the link to the subject 😳
          So next time sign your work πŸ˜‰
          I remember fire in the chimney and wind on the trees β˜€
          • PixeroP Offline
            Pixero
            Just a small update with reflective chrome materials.
            http://www.pixero.com/white
            • Mike LuceyM Offline
              Mike Lucey
              Anssi
              Very impressive work but Annsi has a point when it come to client's on 'locked' company computers.
                Taylor64
                Hi, I've been working on a couple of test projects combining Sketchup and Unity to make walk about presentations.
                I wonder, reading your post, if you ever tried to import the doors or moving objects separately?
                You could move the part in question to the origin assuming the pivot point, then export to .FBX move it to where you want it to be in the scene.
                Just an idea ....
                I haven't tried writing scripts for moving doors yet. Do you have any knowledge you could share on the subject?
                • PixeroP Offline
                  Pixero
                  Just an idea ....
                  I've thought about it but not done it yet.
                    Taylor64
                    Just an idea ....
                    I've tried it and it works, saves me from having to add another step and having to use yet another app.
                    When you have a component in your drawing, "save it as" which will create a new drawing of that component, adjust the origin in the new drawing to where you want your pivot to be , and export it to unity from the same.
                    Just wonder if any of you Guys have experience in writing scripts (Unity) to make e.g. the door rotate or a drawer to slide in and out? πŸ˜„
                    • 2 / 2
