    Arroway Textures
    24 Posts 7 Posters 4.7k Views 7 Watching
    • brodieB Offline
      brodie
      @al hart said:
      We are including an automatic resampling to a width of 1K, 2K, etc. as we create SketchUp and rendering materials from the Arroway textures. We had to do that for our other products since SketchUp users often grab really high-resolution images and place them into models. They look ok for SketchUp, but can really mess up other things like rendering and 3D PDF. (which has to include these huge images in their own 3D model)
      That way the user can easily choose a lower resolution if he/she wants to speed things up a bit.
      Quite true. Sketchup storing the whole image file can be a problem. I just did a quick look and found an arroway texture that's 8,000x8,000 at a whopping 131mb (not the norm, but most of the diffuse maps tend to be in the 30mb range). Doesn't take many of those to slow down your save times considerably. However for me if I'm going to use the full scale image in my final texture I can't reduce the pixel size to 1 or 2k as it messes up the UV's when I export to Maxwell (I'm not sure how other render apps handle this). My solution is to open the file in Photoshop File -> Save for Web/Devices. I set it to JPG with a compression quality of 01. So I maintain the dimensions but the file becomes MUCH smaller. I use that smaller texture in SU and link it to my Maxwell material which uses the full scale version and the UV comes out perfect. Incidently I have to do that whenever I use a texture so if anyone knows of a program I might use to do that in a batch process I'd be interested. Maybe I could do that in PS, but I haven't taken the time to figure it out.
      Another thing I should mention w/ the textures that I didn't know before I purchased them is that they all come in .png format. I, personally, think that .png's are the best thing since sliced bread but there are those who disagree.
      -Brodie
      • brodieB Offline
        brodie
        @gaieus said:
        That itself would already cause some render applications hard times and memory issues - but of course, choose your tool for the project.
        That's probably true, not to mention that more often than not the resolutions will be overkill for most projects. I'm personally willing to take the memory hit though on account of the sample sizes being so large. For Arch-Viz I always find that 95% of the textures out there have too small of a sample size for my taste. Might be ok for interiors but exteriors are a different beast.
        On the negative side I would like to see some more clean textures. Many of their wall textures (plaster, brick, concrete etc.) have a well worn look about them which may be great for some people but typically for Arch-Viz you want to show the building as it would be new, not 10 years down the road.
        -Brodie
          To me, it's the contrary - as I build archaeological reconstructions. And although you exactly know those buildings used to be new once, you somehow expect them to be worn.
          πŸ˜„
          • brodieB Offline
            brodie
            I suppose variety is the spice of life. πŸ˜„
            -Brodie
            • 2 / 2
