    HTML export with hotspots?
    2 Posts 2 Posters 1.0k Views 2 Watching
    • F
      fredrikarvas
      Dear Forum,
      I am building a museum (virtual.vrouwmaria.com) where I have used .jpg-exports from views in Sketchup with html-image-maps to navigate between the pages.
      What I now would like is "view-spots" inside my model, where each wiew-spot would export in 4 different views (the image-export can be done with the http://www.smustard.com/script/CubicPanoOutCubic-script). In these views, with clickable-html-based image-maps would lead the visitor to the next view, like walking inside our museum. Similar to what QuickTime or http://www.easypano.com but without the requriement of any client-application.
      The best would also to use CSS-based-maps instead of html-based maps see: http://virtual.vrouwmaria.com/open/000_Exterior.html (Which I have created with http://www.image-maps.comfor refernces).
      If this script does not exist, what is the cost for develloping it?
      /Fredrik
      • M
        morisdov
        Hello Fredrick,
        Check out Chris Fullmers Camera Recorder -
        http://forums.sketchucation.com/viewtopic.php?f=323&t=23517
        Its quite close to what you asking.
        might require some leg work but should get the job done.
        I also have been working on a Museum plugin for a while, hope to find time to finish it already.
        Myne is definitely not what you are looking for but might be useful for a project like yours - check back in some time.
        Great initiative you have taken on this project πŸ‘
        Cheers
