    đŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Snow Globe
    10 Posts 8 Posters 1.1k Views 8 Watching
    • EarthMoverE Offline
      EarthMover
      On a snow kick today! Must be the 18" sitting outside my house.
      This one is a snow globe. I made the snow using the method I described here - http://forums.sketchucation.com/viewtopic.php?f=81&t=24663&p=211536#p211536
      I used Krill's Create 3D mesh from points plugin on this one.
      I used two globe layers, one inner one which was scaled slightly smaller and textured with a .png image of snowflakes that I mapped in a spherical fashion, per Whaat's UV plugin. I assigned a water refraction value to this layer
      The outer layer is just a standard glass layer.
      3D text done is sketchup using a "Fredo Bevel" on the face of each letter.
      Rendered in Twilight on Easy-Medium with HDRI lighting.
      SU output
      Final
      Content Creator at Skapeup
      • olisheaO Offline
        olishea
        haha wow!! please share that hdri!or at least where you got it from!!
        thanks for texture info, very helpful
        merrrrrryyyyy christmas ho ho ho
        oli
          Luis Esteves
          Nice idea EarthMover.
          It would be funny to create a new thread (or use this one) where everyone could post his own "SCF Snow Globe" 😄
            EarthMover
            Thanks guys. That would be awesome Luis...post any snow globe you like. I guess I should call mine a "Snow Dome" because it's definitely not a globe. Don't know what I was thinking. HAHA It's more like a Holiday paper weight. I love the magnification effect though. The SU output is the actual size of the text. I had to shrink it down to that because the water layer magnifies it so much.
            Oli, the HDRI is either Dosch or Evermotion...can't remember. It's 45MB!
            Here's the snowflake texture I made if you want it.
            Snowflakes_Illustrated_transparent.zip
              d12dozr
              Nice job, Adam!
              👍 Yeah! We're due for a new "Model This"/"Render This" challenge...maybe just add that to your title, Adam. ❓
              http://goo.gl/f7ooYh
              • EscapeArtistE Offline
                EscapeArtist
                Sounds like fun! Could be a holiday or souvenir snow globe.
                  dolphus
                  Could not resist adding my"ORB" I haven't rendered in years (and it shows) just for fun
                  http://i458.photobucket.com/albums/qq304/dolphus_006/orb1.jpg
                    CaptainsLS
                    Nice snow globe Adam, I had some trouble with making the glass on mine. Looking at one, there isnt much magnification on a real glass globe. I wanted to make thick glass but the thicker it got the more distorted....
                      EarthMover
                      Captain, it probably has a lot to do with the lighting in the scene. I have no environment light (sun) in mine, only a single Vray light above and an HDRI for fill and background. This helps play with the glass reflections. Also the magnification effect I experienced, was due to having a 1.33 IOR inner layer which bends light similar to if water was in a glass dome. I would imagine a dome or lens shape may result in greater magnification because of it's shape than a globe.
                      • K Offline
                        kephalos
                        hello
                        nagyon tetszik amit itt lĂĄttam.
                        gondoltam én is csinålok egy hógömböt, remélem belefér a topicba
                        Hello,
                        I like what I saw here very much.
                        Thought I would also make a snow globe - hope it "fits" in the topic here.
                        http://kephalos.extra.hu/hogomb01.jpg
                        Az egĂ©sz vilĂĄg egy nagy tehenĂ©szet –
                        én meg csak ållok itt, és heherészek.
