    Redraw DC
    3 Posts 2 Posters 409 Views 2 Watching
      bsnantes
      Is there a way using ruby script to mimic the Dynamic components redraw option from the context menu.
      I need to up-date the position of a DC (let's say Cube2) which depends on the Z value from another DC (lets say Cube1 ie Cube1!Z).
      Any idea ?
      Is there also a way to create an observer that would react to a DC geometrical transformation ?
      Thanks for your help
        Jim
        I think maybe it is possible. I don't recall any mention of it here on this forum, but if you search for "dc_observers" on the API Group, you may come up with something.
          bsnantes
          Thanks, This works. The problem I'm facing now is that I have added this "target" redraw capacity in a class function which extends DC functions but it appears they can't be referenced in a mouseclick interaction. Only in formulas.
          I have to find another work around. The redraw() function only refresh the DC which calls it. Any idea about a work-around ?
