    Separating a plugin from others
    22 Posts 7 Posters 1.8k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      If you check if your plugin has already been loaded with:
      file_loaded?(File.basename(__FILE__))
      from inside of a rbs file - the FILE value == '(eval)' !
      Sounds like File.basename(FILE) is getting set to part of an eval error string.
      I wonder if eval error strings are put to the $! message global?
      I'm not here much anymore.
      • tbdT Offline
        tbd
        FILE when ruby is scrambled is useless as it gets evaled, so you cannot use it. had the same problem when developing/using Sketchup Bridge.
        workaround: add the path to the global search path for loading scripts $:
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
        • 2 / 2
