    1 way rail - 2 way rail plugin idea
    5 Posts 3 Posters 555 Views 3 Watching
    • P
      pr0bka
      Hey guys, I've been curious is it possible to combine several different ruby plugins into one to perform a single task?
      here's an idea that i thought could work in terms creating a 1 way and 2 way rail surface.
      Heres a link to a plugin that has the ability to create a blend between two shapes in terms of how many segments in between.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=21134&st=0&sk=t&sd=a&hilit=blend
      Is it possible to additionally code this rube to take these particular blends, create a starting point and distribute them along a different spline or arc - and then create a blended surface using the Chris Fulmers loft plugin ruby code?
      here is an image as an example
      The 2 way rail surface would be a bit more complex
      the plugin would first execute a 2 way rail blend along both each axis - along the x/y and along the z and then take the middle distance between each point - generate regular points between then and then generate a surface along those points. There was a plugin I've seen that generated surfaces along points - all that would need to be done is the operation before this one. Would this be an extremely complicated task for a beginner?
      heres example 2
        TIG is on the way πŸ˜‰
        • P
          pr0bka
          Really? wow! can't wait πŸŽ‰
          but about combining plugins, how difficult is that? i have many more ideas concerning geometry and parametric modeling that could use some of the plugins others have made in the past, with their permission of course πŸ˜„
          p.s. is there a drape tool that works horizontally?
          • soloS
            solo
            I do not believe so, however I flip what I need horizontally draped vertical then once I got what I need I re-orientate it.
            http://www.solos-art.com
            • P
              pr0bka
              i know, but a free drape much easier to use πŸ˜„.
              what about multiple weld? or multiple divider (i.e. welding multiple lines/dividing at the same time for lofting purposes? πŸ˜„ )
