    External Visuals [WIP]
    23 Posts 8 Posters 2.0k Views 8 Watching
    • olisheaO Offline
      olishea
      Update on the house I'm working on:
      Twilight and Photoshop πŸ˜†
      http://i654.photobucket.com/albums/uu269/olishea/p1-2.jpg
      oli
      • F Offline
        fymoro
        Look pretty good for a wip Oli... πŸ˜‰
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
        • olisheaO Offline
          olishea
          Thanks fred....will be finished by the end of this week! I've been working on this too long!
          oli
            sepo
            Looks good Oli for WIP...I thought it was Podium πŸ˜‰
            • olisheaO Offline
              olishea
              its a joint venture πŸ˜„
              oli
              • dermotcollD Offline
                dermotcoll
                Very nice - the corbels arent getting any better with the brick render!!!
                When you burn your arse - you gotta sit on the blisters!!
                • olisheaO Offline
                  olishea
                  I was nearly in tears when I started drawing them into the elevations 🀒
                  but what client wants client gets πŸ˜‰
                  oli
                  • stefanqS Offline
                    stefanq
                    Looks fine, and if the client is happy....Why don't you modify this project into a "killer" , only if it is for your own pleasure?
                    • olisheaO Offline
                      olishea
                      hmmmm....
                      oli
                      • olisheaO Offline
                        olishea
                        thnaks a lot james. I haven't drawn everything to (exact) brick dims yet...its almost there but not quite. theres been about 10 revisions! also the texture isn't stretched to standard brick dims eitehr its like 3 mm out at the moment. I know some of the fenestration is unsettling to this elevation in size and relative orientation but I can't do anything about it....its really frustrating-this could be an absolute killer of a house. but then again the client is blown away and loves it! you can't win either way! πŸ˜†
                        oli
                        • RichardR Offline
                          Richard
                          Yeah man! Doing those high box features out of brick just seems heavy and depressing - Oli I can feel your pain! I must say in situations like that I just tell the clients "NO I'm not doing it, whether you like it or not, just no!".
                          Mate you have a funny halo around the background trees (like bloom πŸ˜„) and that brick map just looks a bit plastic not sure why!
                          The grass looks great!!!
                          Well done Oli!!
                          BUILTBRAND.COM.AU
                          • olisheaO Offline
                            olishea
                            Hi people here is another angle:
                            http://i654.photobucket.com/albums/uu269/olishea/visual_north-1.jpg
                            oli
                              sepo
                              This second image looks a bit dark. You have lost definition on the left side of the building.
                              • FrederikF Offline
                                Frederik
                                The shadows on the tree line in the background doesn't match the sun position in the render...
                                The ground material seem too flat...
                                I'm sure that a mixture between NPR and the render will compliment this scene much better... πŸ˜‰
                                Cheers
                                Kim Frederik
                                • olisheaO Offline
                                  olishea
                                  well this is north elevation. this whole side would be in shadow but I kinda faked it so some of it was in sunlight. maybe I shoulda done it with sun off for more overcast appearance. I cant do a NPR render because its in a set of two other (more) realistic renders. cheers for comments they help me improve!!
                                  oli
                                  • RichardR Offline
                                    Richard
                                    Yeah mate what is happening in the shadows there?? Could be someone hiding!
                                    BUILTBRAND.COM.AU
                                    • olisheaO Offline
                                      olishea
                                      Here is the final of the three images:
                                      I couldn't spend longer than a couple of hours on it I'm afraid so please excuse the mistakes here and there!!
                                      I think the images look great as a trio on a drawing sheet, in isolation they are not so spectacular. Remember these are just for planners to get an idea of the building form. I think I went a bit OTT, again!
                                      http://i654.photobucket.com/albums/uu269/olishea/p3.jpg
                                      oli
                                        dermotcoll
                                        Hi Oli
                                        They look pretty good to me - and if they get the house passed for the client then Job done!!
                                        • olisheaO Offline
                                          olishea
                                          and all 3 together:
                                          frederik: perhaps now you can see why I couldn't do just one NPR image on this sheet, it would stand out too much.
                                          http://i654.photobucket.com/albums/uu269/olishea/planning_3_visuals.jpg
                                          oli
                                          • holmes1977H Offline
                                            holmes1977
                                            Great images
                                            I really want to walk with bare feet through that grass.
                                            Exaggeration makes a dull story better.
                                            • 1 / 2
