    External Visuals [WIP]
    23 Posts 8 Posters 1.7k Views 8 Watching
      sepo
      Looks good Oli for WIP...I thought it was Podium πŸ˜‰
      • olisheaO Offline
        olishea
        its a joint venture πŸ˜„
        oli
        • dermotcollD Offline
          dermotcoll
          Very nice - the corbels arent getting any better with the brick render!!!
          When you burn your arse - you gotta sit on the blisters!!
          • olisheaO Offline
            olishea
            I was nearly in tears when I started drawing them into the elevations 🀒
            but what client wants client gets πŸ˜‰
            oli
            • stefanqS Offline
              stefanq
              Looks fine, and if the client is happy....Why don't you modify this project into a "killer" , only if it is for your own pleasure?
              • olisheaO Offline
                olishea
                hmmmm....
                oli
                • olisheaO Offline
                  olishea
                  thnaks a lot james. I haven't drawn everything to (exact) brick dims yet...its almost there but not quite. theres been about 10 revisions! also the texture isn't stretched to standard brick dims eitehr its like 3 mm out at the moment. I know some of the fenestration is unsettling to this elevation in size and relative orientation but I can't do anything about it....its really frustrating-this could be an absolute killer of a house. but then again the client is blown away and loves it! you can't win either way! πŸ˜†
                  oli
                  • RichardR Offline
                    Richard
                    Yeah man! Doing those high box features out of brick just seems heavy and depressing - Oli I can feel your pain! I must say in situations like that I just tell the clients "NO I'm not doing it, whether you like it or not, just no!".
                    Mate you have a funny halo around the background trees (like bloom πŸ˜„) and that brick map just looks a bit plastic not sure why!
                    The grass looks great!!!
                    Well done Oli!!
                    [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                    • olisheaO Offline
                      olishea
                      Hi people here is another angle:
                      http://i654.photobucket.com/albums/uu269/olishea/visual_north-1.jpg
                      oli
                        sepo
                        This second image looks a bit dark. You have lost definition on the left side of the building.
                        • FrederikF Offline
                          Frederik
                          The shadows on the tree line in the background doesn't match the sun position in the render...
                          The ground material seem too flat...
                          I'm sure that a mixture between NPR and the render will compliment this scene much better... πŸ˜‰
                          Cheers
                          Kim Frederik
                          • olisheaO Offline
                            olishea
                            well this is north elevation. this whole side would be in shadow but I kinda faked it so some of it was in sunlight. maybe I shoulda done it with sun off for more overcast appearance. I cant do a NPR render because its in a set of two other (more) realistic renders. cheers for comments they help me improve!!
                            oli
                            • RichardR Offline
                              Richard
                              Yeah mate what is happening in the shadows there?? Could be someone hiding!
                              • olisheaO Offline
                                olishea
                                Here is the final of the three images:
                                I couldn't spend longer than a couple of hours on it I'm afraid so please excuse the mistakes here and there!!
                                I think the images look great as a trio on a drawing sheet, in isolation they are not so spectacular. Remember these are just for planners to get an idea of the building form. I think I went a bit OTT, again!
                                http://i654.photobucket.com/albums/uu269/olishea/p3.jpg
                                oli
                                  dermotcoll
                                  Hi Oli
                                  They look pretty good to me - and if they get the house passed for the client then Job done!!
                                  • olisheaO Offline
                                    olishea
                                    and all 3 together:
                                    frederik: perhaps now you can see why I couldn't do just one NPR image on this sheet, it would stand out too much.
                                    http://i654.photobucket.com/albums/uu269/olishea/planning_3_visuals.jpg
                                    oli
                                    • holmes1977H Offline
                                      holmes1977
                                      Great images
                                      I really want to walk with bare feet through that grass.
                                      Exaggeration makes a dull story better.
                                      • RichardR Offline
                                        Richard
                                        Still needs some shadows and highlights filtering on that middle one mate! Still so dark!
                                        • olisheaO Offline
                                          olishea
                                          its cool i've done it to the printed version cos it was too dark πŸ˜„ so thanks for pointing it out! I didn't have time to re-render 😒 but they look fab on paper!!
                                          cheers holmes......but keep off the grass 😎
                                          oli
                                            holmes1977
                                            lol nice..........sunny day, grass on the grass..... not forgeting the bare feet 😎
