    Ruby MySQL module in Sketchup
    2 Posts 2 Posters 472 Views 2 Watching
    • P
      Pauline01
      helloooooo!
      I have a problem!
      I run a script ruby with ruby console in sketchup.In this script i need to do MySQL queries, i have MySQL module in my Ruby 1.9, when i run my script with prompt ruby console (no with ruby console in sketchup), all MySQL queries are ok ( at begining i need: require "mysql" ).
      How i can do to have the same things with Sketchup when I use: require "mysql"???
      To test i need to run this script which require "mysql":
      require "mysql"
      begin
      # connect to the MySQL server
      dbh = Mysql.real_connect("localhost", "testuser", "testpass", "Motor_control")
      # get server version string and display it
      puts "Server version: " + dbh.get_server_info
      rescue Mysql::Error => e
      puts "Error code: #{e.errno}"
      puts "Error message: #{e.error}"
      puts "Error SQLSTATE: #{e.sqlstate}" if e.respond_to?("sqlstate")
      ensure
      # disconnect from server
      dbh.close if dbh
      thx to help me 😄
      Pauline
      • daikuD
        daiku
        Hi Pauline.
        If I understand correctly, your problem is executing a "require" command from the console window? If so, here are 2 things to keep in mind:
        • Specify the full path (note how in my example, the first fails, but the second works)
        • Use the '/' character, not '' for the separator.
        require 'reglue.rb'
        false
        require 'C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/reglue.rb'
        true
        Clark Bremer
        http://www.northernlightstimberframing.com
