    How to batch export (and reduce in size) multiple textures??
    6 Posts 4 Posters 468 Views 4 Watching
      AcesHigh
      I could swear that there was a plugin to batch export multiple textures (for editing) instead of manually clicking each one and selecting "export - save", etc.
      I basically have some 3D Warehouse models that are huge (10mb) because of bad textures (too big, saved at 100% jpg quality, etc). But the model is composed of MANY small textures...
      Batch exporting them all would already help... of course, if there is some method of automatically reducing their size, or at least reimporting them, that would also be cool 😄
      • E Offline
        Ecuadorian
        Batch export: Twilight's XML button.
        Batch reduce in size: Irfanview.
        -Miguel Lescano
          AcesHigh
          this is the name of a plugin?
          • E Offline
            Ecuadorian
            Yup, it's a commercial rendering plugin, actually. You can also use the free Kerkythea exporter by Tomasz for the same purpose. Just export the model to a folder, and all textures should be written to that folder.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=22520&start=0&st=0&sk=t&sd=a
            -Miguel Lescano
            • Chris FullmerC Offline
              If you save your model as a .3ds file format, I think SketchUp will write out all the included image files, so you can access them all. I puts them in the same place that it puts the .3ds model. Try that,
              Chris
              All my Plugins I've written
              • ArcA Offline
                Arc
                Didier Bur's plugin:
                [Plugin] Very fast texture writer
                http://forums.sketchucation.com/viewtopic.php?f=180&t=6386&p=156132&hilit=Very+fast+texture+writer#p40025
