    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Urban rejuvenation UPDATED
    31 Posts 25 Posters 2.8k Views 25 Watching
      troyhome
      always excellent work. did you model those blinds in SU or Max?
      IOviz.com
      SU Pro 2024 PC
      • olisheaO Offline
        olishea
        great work pete, very 'seattle' feel to it
        oli
        • FrederikF Offline
          Frederik
          Really nice, Pete...!! πŸ‘
          As usual it's very inspiring - as well as a joy - to see your work...
          And I see that we share the same taste when it comes to the art on the wall... πŸ˜‰
          (except you've turned the immage 90 degrees...)
          Cheers
          Kim Frederik
          • jeff hammondJ Offline
            jeff hammond
            nice!
            props to you sir.
            dotdotdot
              jeff jacobs
              Nice images Pete. There is no doubt that vray is the best renderer on the market including Maxwell. The light and glass are fantastic.
              C'mon mac version!
              • marked001M Offline
                marked001
                wow.. awesome presentation! such a great idea.
                http://www.revision21vis.com
                instagram: revi21on
                • boofredlayB Offline
                  boofredlay
                  Inspirational yet again Pete.
                  http://forum.psychlinks.ca/images/smilies/clapping.gif
                  • P Offline
                    Prisoner
                    Impressive work... as always πŸ˜„
                    I'm a big fan of your art since starting to watch this forum.
                    • soloS Offline
                      solo
                      Thanks guys.
                      Troy, the blinds are Max models, imported into SU.
                      Oliver, you from the UK right? Seattle is like London so they say, must be a weather thing. πŸ’š
                      Frederick, yup we certainly do, I am not 100% sure of which orientation is correct, but judging from the signature, WH and one other site I googled, the orientation I used seems to be what Sascha intended...I guess it's subjective to taste really.
                      Jeff, I must say that light with an unbiased engine is hard to top, but the attraction with Vray is the speed and quality, had I been a purist without a time handicap I'd let it run for a few days with an unbiased engine, but in the real world deadlines need to be met and Vray certainly is an amazing app for just this.
                      I have another set that was not used for reasons I'm not sure, anyway this is a female toilet conversion to Nana wall bathroom.
                      For better quality
                      See bottom slideshow: http://solosplace.com/RENOVATIONS.aspx
                      Here is a video, quality is a little sucky.
                      [flash=640,360:2ool8gy4]http://vimeo.com/moogaloop.swf?clip_id=7065353&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=&fullscreen=1[/flash:2ool8gy4]
                      Color banding is due to .tiff to .jpg compression.
                      http://www.solos-art.com
                        teofas
                        good work solo, i like how you explain the desing process in those animations, very clear,,i have minor thing to comments that i think can improve the renders, i think it can be more bright cause i found them a little dark, also the exterior background seems a little desaturated and the perspective i think is wrong, but in all i like your work and this is only said with the best intentions my friend. πŸ˜‰
                        http://www.spazioarquitectura.com
                        • soloS Offline
                          solo
                          Thanks, the city outside the windows has a 30% transparency as I wanted it not to overpower the scene, the perspective of the city I guess could seem a little off.
                          Before:
                          http://img63.imageshack.us/img63/3997/v2before1000.png
                          After:
                          http://img26.imageshack.us/img26/8641/v2ater1000.png
                          • 2 / 2
