    [WIP] Interiors -will be my first PR renderings
    64 Posts 16 Posters 6.8k Views 16 Watching
    • tinanneT Offline
      tinanne
      I have this client who has asked me to try a couple of PR renderings. Even though it's just a trial run, I'm a little nervous.. I'm still getting paid. I thought I would start posting my progress and see if there is any input that I can get at the start of the project (and along the way) and not when I'm 6hrs away from my deadline about to have a coronary because things are not working out well!
      I still need to add accessories to the walls and shelves, etc., but here is the first draft.
      Bedroom
      Living Room
      Executive Director : American Society of Architectural Illustrators
      AIP 30 Competition opens soon. ASAI.org
      Architectural Rendering
      • E Offline
        Ecuadorian
        Well, a good render starts with a good model, so you're having a good start here 👍
        -Miguel Lescano
        • daleD Offline
          dale
          I appreciate you spending the time to do this. I look forward to updates. Nice work so far 👍
          • E Offline
            Eulgrand
            Eager to see what's next !
            • RichardR Offline
              Richard
              Yeah nice scene so far but you need to start tests early or you may find your chasing a lack of light later!
              And remember PR brings in all sorts of details one has never had to consider with NPR, for example at the line where your walls meet the floor and ceiling, do they just intersect or actually have some treatment? Details, details, details!
              BUILTBRAND.COM.AU
              • tinanneT Offline
                tinanne
                Thanks Richard, good point.
                There is no molding at the ceiling line, only on the columns so I think we are set there.
                More to come. 😄
                • tinanneT Offline
                  tinanne
                  Progress on the test runs.... not so good! I'm already frustrated!
                  I'm using Podium 1.7. I've used podium on some smaller projects and loved the output, but every time I try to use it for a larger project I have nothing but problems! Constantly crashes, I don't get the "quick" results that everyone else seems to get, and the lighting is horrible. 😞
                    sepo
                    What exactly are the problems? Maybe I could help.
                    • olisheaO Offline
                      olishea
                      sometimes changing preset can solve the problem. I seem to get crashes (or white renders) when I use optimalem preset with lots of omnis......try quality or noisy. If you post problems on podium forum everyone will help, its a very friendly place!
                      oli
                      • tinanneT Offline
                        tinanne
                        Thanks Sepo. I keep trying Podium, but I just keep giving up. SU constantly crashes. That is the most frustrating part.
                        Puter specs:
                        AMD Athlon 64 x2 5400 3GHz
                        4GB of RAM
                        Video-I can't remember but I'll get you stats later
                        I've set up my scene, shadows on. I've tried every setting I have and most of them crash. I've tried default, sepos smooth setting, fab interiors, optimalem... the list goes on.
                        • soloS Offline
                          solo
                          Tina, I also run a 64 bit rig, if you want to send me the model and I will see if it happens to me also, I guess that way we can eliminate it being Podium if it does as my Podium seems very stable.
                          http://www.solos-art.com
                          • tinanneT Offline
                            tinanne
                            Thanks Pete, it's on the way!
                            • soloS Offline
                              solo
                              Tina, it did render on my side, but it took a while to process geometry and warm up, I tested it on default (I have not got the other presets loaded besides the standards on my new rig).
                              I guess it may be overloading your machine as the scene has 821 lights, 2593 reflective surfaces.
                              I then reset the model, and it rendered in 1m 40s, however when I tried to add lights (omnis) SU crashed and kept crashing after that, so it looks like it may indeed be a combination of model and Podium.
                              • olisheaO Offline
                                olishea
                                sounds like a geometry or texture issue to me, more likely geometry.
                                sometimes just one dodgy texture or component can cause the crashing. I would delete components one by one and reset all materials and keep testing til it stops playing up (oh and purge all if you haven't already). 2593 reflective faces isn't too excessive for podium, just one car has that amount and normally its very stable. Why so many lights?
                                oli
                                • E Offline
                                  Eulgrand
                                  • soloS Offline
                                    solo
                                    The lights are LEM's, so it could be a sphere that's lit up.
                                    • david57D Offline
                                      david57
                                      That looks beautiful, I like it. I dont know what PR or NPR is.
                                      • E Offline
                                        Eulgrand
                                        Thanks for the explanation 😉
                                        • FrederikF Offline
                                          Frederik
                                          Looking forward to see the progress of this...
                                          The scene has a good potential... 😉
                                          Cheers
                                          Kim Frederik
                                          • E Offline
                                            Ecuadorian
                                            Try using the Metropolis Light Transport render method. In MLT, the number of light emitters is totally irrelevant. You can have 8 or 2048 emitter faces and the render time will stay the same.
                                            Metropolis light transport - Wikipedia
                                            (en.wikipedia.org)
                                            -Miguel Lescano
                                            • 1 / 4
