    Transformations
    23 Posts 10 Posters 16.3k Views 10 Watching
      cjthompson
      The transformation.axes method just transforms the object so that it's axes match the internal ones.
      try using transformation.axes on the grouponent (I believe you used that one πŸ˜‰)
      then use
      grouponent.entities.transform_entities(grouponent.transformation.inverse,grouponent.entities.to_a)
      EDIT: Just tried it and it should work.
        cjthompson
        I just looked at the picture you posted again. Do you want flip the axes, instead of rotating them? If so, I don't know if that is possible. It's has to do with the fact that sketchup uses a right hand orientation, instead of left-hand orientation that I'm guessing LDraw uses (http://en.wikipedia.org/wiki/Right-hand_rule).
        Is there a way to change the orientation of axes in LDraw? (I haven't used it myself, so I have no idea)
          Jim
          One of the reasons I asked was that I wrote this LDraw importer. But the LDraw axes system does not match SketchUps, and I really want the importer to correct this on import. You can see the import works, but I haven't been able to figure out how to trasnform the geometry during the import so it uses a SketchUp axes that people are familiar with using.
          • 2 / 2
