    Is This Lazy?
    2 Posts 2 Posters 803 Views 2 Watching
    • J
      Jim
      Is this an acceptable idiom when using Ruby, or just being lazy? Other than not "seeming" right, is there a down-side?
      begin
        Sketchup.active_model.start_operation("Op", true)
      rescue ArgumentError
        Sketchup.active_model.start_operation("Op")
      • A
        avariant
        There will most likely be some performance hit, but it's not likely to be significant. My personal opinion is that if it is reasonable to code the appropriate "if" conditions (like version number), you are better off doing that. For a simple issue like this, probably irrelevant; for more complex code, you'll want to be more careful.
