    Green Kitchen...
    14 Posts 6 Posters 1.0k Views 6 Watching
    • F Offline
      fymoro
      hi all,
      Here is a new work.... The cabinets are from the Web (3ds), but when I imported them into SU, it was a real mess, and I worked 2 hours to restore order ... 😲 After this work I can say that they are my models... 😉
      medium + rendering : 6 hours.
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • marked001M Offline
        marked001
        good start... definitely a little 'dull' though..i know its a night scene, but it needs to be a bit brighter...
        http://www.revision21vis.com
        instagram: revi21on
        • FrederikF Offline
          Frederik
          Although I don't like the green color, the render itself is really good and convincing... 😄
          Cheers
          Kim Frederik
          • olisheaO Offline
            olishea
            I agree with marked001. While it is very convincing, it needs more 'punch', tweak the levels and curves maybe.
            nice work
            oli
            • stefanqS Offline
              stefanq
              Fred, you still have v-ray, right? Why don't you try to render this one with it, because,6 hours it's just too much.
              I bet you can do better materials too.
              • F Offline
                fymoro
                Yes you all right, I will try to make it better, and just a quick try with Vray to see... 😉
                • F Offline
                  fymoro
                  Here is a quick setup (15 minutes for light and materials) to render and try this kitchen with Vray first version.
                  Ok , it is more realistic and less noisy on this image, and really quicker =render time (less than 12 minutes), but I have to say that the IES effects are faked and difficult to setup, and to put a Background it is not easy as Twilight interface.
                  So Is there some big change between the first Vray version and the last one ? IES light effects ? easy background ?
                  I wait your comments... 😉
                  Cheers Fred.
                  • FrederikF Offline
                    Frederik
                    The VfSU render sure is nice, but since the lightning and scene setup is far from identical, you can't compare it directly... 😐
                    The lightning in the scene rendered with TWR is a night shot and the VfSU is a daylight scene...
                    I'm quite certain that I can render the daylight scene with TWR in less than 20 minutes...
                    (Please note that I'm not saying TWR is faster than VfSU...)
                    Cheers
                    Kim Frederik
                    • F Offline
                      fymoro
                      Hi Frederik,
                      It's true, it is not the same scene so I can't compare them.
                      Can I send you the scene in private, and if you have time to render a day-scene ?
                      Twilight is a good software, and of course I need more experience... 😄
                      Fred.
                      • FrederikF Offline
                        Frederik
                        Of course you can... 😄
                        I will send a PM with my e-mail address... 😉
                        Cheers
                        Kim Frederik
                        • F Offline
                          fymoro
                          Here is another render with TL, DOF is so easy to setup in TL, two click on the mouse and it's done.... 😉
                          I used preset 10 for 7 hours and 165 passes.
                          Cheers Fred.
                          • F Offline
                            fymoro
                            Final render,
                            Night and day shot, Problem with my spot light resolved, Thanks to Kim... 😉
                            I used preset 10, 2 hours each... No PS just TL 😄
                            • soloS Offline
                              solo
                              http://img15.imageshack.us/img15/792/dinnerguest.jpg
                              http://www.solos-art.com
                              • F Offline
                                fymoro
                                Pete, It's awesome... 😲, You and Twilight... 👍
