    Use Sketchup default cursors
    23 Posts 7 Posters 8.2k Views 7 Watching
    • Dan RathbunD
      Dan Rathbun
      @thomthom said:
      Do SU use .cur files? Isn't it just .png?
      Yes your right Thom, I boo-boo'd. Posted before I tested.
      SU does NOT recognize ****.cur**** files. If you try it the id for the cursor = 0. (I'm once again flabbergasted at whomever wrote the SU ruby API. They've earned 20 lashes with a Nerf-Noodle!)
      The API states 'image' but does not say what formats are acceptable.
      I've already begun extracting the 4 images files from the cursor files, decided to do a bit of anti-aliasing work on the edges of the pencils.
      DONE (Original posting now has updated zip with png images for SU cursors and buttons.)Get them...
      Will also look at the Windows API and see if I can cobble up a system call to load a cursor file instead of making a call to UI.create_cursor, as UI.set_cursor should not care how the cursor got loaded into memory, it only wants a pointer (id). [Some testing has shown the UI.set_cursor canNOT deal with Windows Cursor resources, so a 'special' set_win_cursor method would be needed, using a direct Win32 API call.]
      I'm not here much anymore.
      • eneroth3E
        eneroth3
        @thomthom said:
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#create_cursor
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#set_cursor
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/tool.html#onSetCursor
        These links you give me 404 errors 😒 . I know I've read about this somewhere else recently but can't remember where now.
        EDIT:
        It might have been from when I read in TT lib the other day to understand how the win32api works. Found this page now: https://bitbucket.org/thomthom/tt-library-2/src/9ff3a5f08604ed477eb4b17fd63612bfc42832dd/TT_Lib2/cursor.rb?at=Version%202.9
        My website: http://julia-christina-eneroth.se/
        • tt_suT
          tt_su
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/ui#set_cursor
          http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool#onSetCursor
          • 2 / 2
