    Pickup an object
    13 Posts 4 Posters 1.6k Views 4 Watching
      christcm
      Does anyone know how I can join two objects during an SP Animation? I have a functional Tower Crane but I would like to simulate it picking up a load. I can't figure out how to lower my hook and attach the load to it. Any help would be appreciated.
        christcm
        Ok there has been no response yet but this is what I have done so far. Since I can't get the objects to attach in the animation I have made a hook and a ring. The hook is on the crane and the ring is attached to the load. I have checked the collision properties and the hook and ring both are the correct shape for their intended purpose. However when I get them into place the hook slips right through the ring after a second of trying to lift the load. Is there anything I can do to prevent this?
        • P Offline
          phy
          Can you upload the model, it makes it way easier to troubleshoot.
          Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
            christcm
            I have figured out how to pick up the load. I just needed to beef up the size of my hook and the size of the ring (in cross section diameter). I added a clasp on the hook to keep the load on as well. I tried to attach the model but it is too large.
            • H Offline
              hpnisse
              Hello!
              Is there any way to pick up somethinge with a script?
              I have one script:
              ontouch{|toucher,s,p|
                 if getVar("var1")==1
                   case toucher.name
                       when "NAME"
                          connect(toucher,"fixed")
                 else
                    ontouch{} #turn off ontouch event.
              But this script do not work, cause when it hit an object will the Sketchup and Physics freeze.
              So, is there a script that can be turned on with a "getVar("Var")==1", and when the "var" is 0 it will release the object, just like pneumatic vakum.
              Thanks for any help!
              /hpnisse
              ` /hpnisse`
              ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
              • P Offline
                phy
                ontouch{|t,s,p|
                   if getVar("var1")==1 && t.name=="NAME"
                                connect(t,"fixed")
                There you go, but remember you can't upload the model to the warehouse cause your using the June 27 version of sp. you can post the model here though.
                • H Offline
                  hpnisse
                  Thanks for that, but it will freeze when the "hook" touch the box. Why??
                  Se if you, or someone else can get it to work.
                  PICK MASKIN.skp
                  (all stuff is controlled by sliders)
                  thans again.
                  ` /hpnisse`
                  • P Offline
                    phy
                    if slider("var1")==1;setVar("var1",1);else setVar("var1",0);end
                    put that in the ontick in place of
                    slider("var1")
                    only problem is once it rejects it, it rejects it and when it picks it up it picks it up 😕 🎉 😒
                      camokid11
                      a simple idea would have been to use a controled magnet which has some stabalising around it to stop it from spasing out. simple is always better, why need long scripts
                      If you can read this, thank a teacher.
                      If you can read this in english, thank a soldier.
                        christcm
                        How would you use a controlled magnet? I started with a magnet but it didn't cause the two objects to stick together for me.
                        • H Offline
                          hpnisse
                          I didn´t get the script idea to pickup an object to work, it will always freeze.
                          and if I use a controlled magnet: the SP.Simulation wont start, and when I press "resetPhysicsSim button" this box come up:
                          error resetting the simulation: : undefined method ´/´ for nil:NilClass
                          C:/Program Files/Google/Google Sketchup
                          7/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1270:in
                          ´resetSimulation
                          wierd??
                          (and there can not be the Physics Installation that did´t work cause when I start a new Sketchup and start it will work just fine)
                          Anyone that can fix the problem with either the script system or the magnets?
                          thanks:D
                          /hpnisse
                          ` /hpnisse`
                          • P Offline
                            phy
                            what version are you using?
                            • H Offline
                              hpnisse
                              In menu,
                              Help/About Sketchup Physics:
                              SketchyPhysics3.
                              hh´ttp://code.google.com/p/sketchyphysics2
                              Copyright 2009 C Philips.
                              In the simulation window:
                              SketchyPhysics3x Jun 27
                              so I guess it is SP3x
                              ` /hpnisse`
