    My First Render
    9 Posts 6 Posters 636 Views 6 Watching
      stann_ph
      Please comment... thanks
      • FrederikF Offline
        Frederik
        For a first time render, this is really nice... πŸ‘
        The lightning is in good balance and makes the render appear very real...
        What render app. did you use...??
        Cheers
        Kim Frederik
          stann_ph
          πŸ˜„ thanks.. nyway i use vray for sketchup. πŸ˜„
          • brodieB Offline
            brodie
            Looks great for a first render. Seems a bit noisy though, isn't Vray a biased renderer? Something seems a bit off on the wall material too, maybe too big? Just nitpicky stuff though, you're well on your way with the essentials.
            -Brodie
              teofas
              first render? very good! you should see my first render, it was not even half as good as yours, congrats!!
              http://www.spazioarquitectura.com
                steelers05
                yeah good start but you need to get rid of the noise...maybe up your light cache and IRmap settings. Kepp goin
                  stann_ph
                  i change some settings, my 2nd render πŸ˜‰
                  • brodieB Offline
                    brodie
                    That's looking better. My next suggestion would be to work on your textures. The wood texture on the crown molding has a lot of noticeable tiling. And all the tiles on the wall look exactly the same so I'd find a better tile texture. There are some good texturing site links elsewhere on these forums.
                    -Brodie
                    • michaliszissiouM Offline
                      michaliszissiou
                      Thats a great render πŸ‘
                      But its an 60K jpg. Most of the noise comes from jpg compression, you can check this. Make it around 150-200K and post this again. Vray is a great renderer, biased or unbiased. When we're talking about a renderer, see how corners look first. Here they look natural.
