    Restaurant WIP
    7 Posts 4 Posters 875 Views 4 Watching
      Aidus
      Update:
      Another 5h render.
      Night
      Just a quick render of whole building. As You can see in background it is not finished. Lots of corrections need to be made but I hope it will take max one or maybe two weeks.
      http://www.bildites.lv/images/0ncmek3t1zez4x83u9s8.jpg
      As usual modeling just in SU and maxwell render. And SU wire:
      http://www.bildites.lv/images/ka7mfaeg6teq87fmawjg.jpg
      CPU: Intel Core i7 Extreme Edition 965
      RAM: OCZ Gold DDR3 1600MHz 12Gb
      Video: Asus Radeon HD4870 X2 2Gb
      Mobo: Asus P6T Deluxe 1366 Intel X58
        smokinbakin
        Wow, very impressive. Looking forward to seeing more exterior renders.
        "Set your goals low, and hope you don't get lower"
        • marked001M Offline
          marked001
          wow is right...this should be pretty impressive, indeed.
          the wood is loooking a little plastic-y at the moment... maybe too smooth or too shiny or both?
          http://www.revision21vis.com
          instagram: revi21on
            Aidus
            Here I have a small update of the project:
            http://www.bildites.lv/images/va6vuba9cvkzv5iilem.jpg
            Soory about terrible photoshop πŸ˜„
            Currently I need to work on another project and I will continue this model as soon as possible.
              smokinbakin
              Great work, the roof texture looks good. Keep it up πŸ‘
                Aidus
                Maxwell v 2.0 demo render. Similar project.
                Night:
                Test
                  troyhome
                  First of all- you get great projects!
                  Looks really impressive! the black and white rendering is revealing as to the material qualities of the building. I'm going to have to start using this as a design tool.
                  Good stuff!
                  IOviz.com
                  SU Pro 2024 PC
