    Toggling Thrusters?
    8 Posts 5 Posters 1.1k Views 5 Watching
      BLANK
      Hi. The whole SP3 thing is a huge improvement over the previous one and there doesn't seem to be a "SP For Dummies: Toddler Edition" anywhere that explains the scripts in plain english.
      So I was wondering if there's a way of turning on/off a thruster with a keystroke? I understand that it's possible (with Wacov's code) for emitters, but not the same case for thrusters. Tried my best with the guessing, but no success. Help?
      If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
      • P Offline
        phy
        Yes there is a toggle script. http://sketchyphysics.wikia.com/wiki/Advanced by Wacov.
        Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
          BLANK
          That does work, but I don't know how to set the speed/force. Help?
            JaViXP
            For thrusters... I am not sure.
            Try using this in 'onTick'
            push(1)
            Note: You can change the 1 for the value you want.
            "Giving up is way harder than trying"
            JaViXP's Rendering
              MrPlanet
              (if frame==1;setVar("repeat",0);setVar("toggle",0);end;if key("space")==0;setVar("repeat",1);getVar("toggle");elsif getVar("repeat")==0;getVar("toggle");elsif getVar("toggle")==0;setVar("repeat",0);getSetVar("toggle",1);else;setVar("repeat",0);getSetVar("toggle",0);end;)*1
              The '1' at the end is thruster power
              Space is the keystroke
              Now i can haz catnipburger? 🤣
              I reject your reality and substitute my own.
              • P Offline
                Physicsguy1
                So you want to toggle a thruster? If you are using Wac's script, remember that the output is getVar('toggle'). I would suggest putting this in the thruster script field: getVar('toggle')*value.
                  BLANK
                  Thank you all for your input.
                  *value
                  *1
                  Damn, it's that pesky little star that I kept forgetting about...
                  Why, yes.
                  http://images.inmagine.com/img/bananastock/bs212/vic056.jpg
                  Help yourselves.
                    MrPlanet
                    Mmmmmmm... Catnip 🤣 🤣 🤣
