    Changing name of joints in control panel.
    2 Posts 2 Posters 616 Views 2 Watching
    • P Offline
      prykpryk
      I have problem. I can't change name of joints (servo)in control panel. In mine model are ~11 servos and every named like servo16700. I can't steering like that. How change it?
        Sgt.A.Johnson
        Its a very simple task. select the joint and then next to the play button for sketchyphysics there is a button that says UI on it. click it and depandant on whether you have sketchyphysics 2 or 3 their will be a text field called controller. if you have sketchyphysics 2 just type what you want the slider to say. if you set 2 or more joints to the same name one slider will control both joints. in sketchyphysics 3, due to the new coding features you will have to put: slider('[slidername]')
        For example if i wanted the slider to be called steer i would put:
        slider('steer')
        Once again if 2 or more joints have the same slider name they will both use only 1 slider.
