    Oscar Boolean plugin
    7 Posts 4 Posters 1.9k Views 4 Watching
    • mitcorbM
      mitcorb
      What is the status of this plugin?
      I have it, but does not seem to work. I am probably not using it correctly.
      • J
        Jim
        I haven't seen the author post in a long time. I hope all is well and he can give an update.
        I'm sure you are already aware of Dale's BoolTools ($10) plugin?
          Draw each volumes
          each volume must be a "group"
          Select one group
          right click / boolean operation you want
          • mitcorbM
            mitcorb
            Thank you, Jim and Pilou.
            Regarding BoolTools: Is the license portable? I have access to more than one machine with Sketchup versions 6 & 7, free and pro. I have not seen any info on this.
            Pilou, I will try your advice. I really enjoy your visual examples in this forum.
            Regards,
            mitcorb
            • R
              remus
              Im not sure if the booltools license is a floating one, but if you contact whaat im sure he'll be happy to clarify.
              Having said that, i cant imagine any reason it wouldnt be, as long as other people are not going to be using the plugin on the other machines.
                Videofor Oscar's plug 😉
                • mitcorbM
                  mitcorb
                  Well, Pilou:
                  My version of this plugin just sits there and I have tried all combos of group, no group, select all, select some, select none and right click select operation. No results.
                  Just for your info.
                  mitcorb
