    Commercial Building
    9 Posts 8 Posters 826 Views 8 Watching
    • E Offline
      EDMON242004
      Hello,just posting a work for CC as usual, thanks πŸ‘
      • boofredlayB Offline
        boofredlay
        Great image. The only thing I would change is the grass texture.
          rdluther
          looks like a very cool model. are there any other images from different angles? the angle does not seem too flatering for the model, closer and off the "turret" corner might be a better angle to show the detail.
            dylan
            Cool looking building and nice render.
            Agree with Eric, could do with a better grass texture.
            What did you render this with and has it got an overlay on their?
            http://dmdarchitecture.co.uk/
              Sir
              the building mass as a whole is a bit flat, and doesnt really have an end...
              id suggest mixing up the overall aesthetic a bit, bring up an end or something.
              nice image tho
                Macker
                You definately need some kind of anti-aliasing filter on that.
                Check out my blog @ http://macviz.blogspot.co.uk
                  skyscraper100
                  nice modelling and rendering!, galing!
                  The way you think Creates reality for yourself.
                  • marked001M Offline
                    marked001
                    love the building/model....love the sky...love the lighting... seems like a pretty dramatic image.....but like other have said...you've got to do something with the grass...maybe comp it in like you did the sky? great job though.... what renderer?
                    http://www.revision21vis.com
                    instagram: revi21on
                    • E Offline
                      EDMON242004
                      Hello thank you for the suggestions, the grass actually has a bump map on it but it doesn't seem to work, I used Vray for rendering, after knowing Vray for SU I dropped max and start to use SU+Vray.. I will adjust the composition since this is still a W.I.P., and by the way Mac could you explain this anti aliasing filter a bit so I could apply it? I hav here another angle but the glass destn't have reflections yet I am stil; searching for a nice looking reflection image if you guys can recommend one to me please do.COMMERCIAL 1B copy.png
