    Adding Item To Sub-Menu?
    2 Posts 2 Posters 304 Views 2 Watching
    • P
      Physicsguy1
      I have a sub menu that contains my W.I.P plugins. I have trouble adding items to it. I can't find the code that does it in the API Index. How do I do this?
      • Chris FullmerC
        http://code.google.com/apis/sketchup/docs/ourdoc/menu.html#add_submenu
        plugins_menu = UI.menu("Plugins") submenu = plugins_menu.add_submenu("Test") submenu.add_item("Plugin Name") { plugin_method }
        That should do the trick.
        It gets a little trickier if you want to multiple different plugins to the same sub-menu, but its possible. I use a global variable, but Jim showed me a way to do it without the global.
        Chris
        All my Plugins I've written
