    My once Projekt
    11 Posts 4 Posters 826 Views 4 Watching
    • P Offline
      Patrickpr
      Hy
      Here extremely good projects of Sketchup are gepostet!
      My Projekt is not good against the other projects!
      Please here the pics
      • artysmediaA Offline
        artysmedia
        It is a good first model, Patrick!
        I think you may put more details in the model.
        Try to use groups and create components
        You must try to use real measures so that you feels the model more correct
        Search better textures
        Go on! πŸ‘
        Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
        Blog: Artysmedia
        • P Offline
          Patrickpr
          Thank you πŸ‘
          Yes i have download me very good textures!
          • P Offline
            Patrickpr
            By my swimbad i will see the Bottom
            I am see the texture!(picture)
            Can you help me?
            • F Offline
              fefillo
              Can you help me?
              I think you mean that you want to see the bottom of the pool with the texture you have, right?
              Go into the Materials window and Edit the opacity to something lower than 100%.
                artysmedia
                Very fast fefillo! πŸ‘
                http://www.dgp.toronto.edu/~stam/INRIA/Images/caustic_jitter.gif
                http://farm1.static.flickr.com/44/136621898_d0a9030afa_o_d.jpg
                Blog: Artysmedia
                • P Offline
                  Patrickpr
                  THANK YOU
                  I have a problem πŸŽ‰
                  How enfterne I these lines? around the house
                    artysmedia
                    What is enfterne?
                    Maybe is it hide?
                    Over a line, Right click / Hide
                    Blog: Artysmedia
                    • P Offline
                      Patrickpr
                      Sorry deteled πŸ˜„ is enferne
                        If you delete those lines, the face will disappear, too. Hide them instead; use the Eraser tool combined with the Shift key. If they are in a group, you have to edit the group first.
                        • P Offline
                          Patrickpr
                          I have first make a Rectangle, on the Rectangle i have make the house!
                          Then i have make with the sand box around the Rectangle a Area!
                          When i deteled the lines than is the Area around the Rectangle is disappeared! (With the SHIFT key also)
                          What can i make??
