Simple Loft tool from Chris Fullmer
Hi Chris,
i use your tool as the first important Step to get the curvature of a terrain along a planned road direction. The tool worked fine on different terrains. But with the terrain below it produces a Bugsplat. I don't know why.
Karlheinz
Hi Karl, I'm not sure what the problem is. It worked just fine for me.
For something like that though, you don't even need a tool like simple loft. Check out this this video that shows a simple way, just using the default SketchUp tools.
[flash=489,468:j5sxc824]http://chrisfullmer.com/forums/push_pull_karl.swf[/flash:j5sxc824]
Chris
Thank you very much for your efforts Chris,
i was so much fixed on the loft tool that i couldn't see this simple way.
Karlheinz
