    SketchyPhysics 3 Problem
    7 Posts 4 Posters 957 Views 4 Watching
      darkPhysics
      Hey i have a big SketchyPhysics 3 X April 5 problem. I can run SketchyPhysics,but as soon as I try to run the model from 3D Warehouse i get this error:
      http://img19.imageshack.us/img19/327/errorudb.jpg
      • H Offline
        hpnisse
        Have you try reinstall the SP3? 😄
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
        • P Offline
          phy
          Click on windows and go outliner, do you have an empty group. If so delete it. Also do you have the plugin Loft by Chris Fullmer
          did that fix it
          Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
            darkPhysics
            to hpnisse yes, I tried to reinstall SketchyPhysics
            to phy i have loft plugin from Chris Fullmer and there is no empty group
            I looked now an it works. It probably needed a restart. Thank you all for fast response.
            darkPhysics
            • P Offline
              phy
              There is a bug between loft and sketchyphysics, loft creates a empty group that sketchyphysics can't handle. Thanks goes to physicsguy for the work around. Every time you want to play a model you will have to go into outliner. I think outliner automatically deletes the empty group.
              • P Offline
                Physicsguy1
                I could try to create a plugin that will terminate it, if possible, if the problem persists.
                • P Offline
                  phy
                  Well Cris Fullmer said he'd try to fix it. But if you want to create a plugin in the mean time you can.
