    Tower blocks
    10 Posts 6 Posters 814 Views 6 Watching
    • StinkieS Offline
      Stinkie
      Not too sure about this one. Have been staring at this for hours now. Can't tell anymore whether to ditch it or not.
      • 2 Offline
        21D
        I vote "NOT" ๐Ÿ˜œ
        I like the design and the render, maybe if you do stick with it you might even improve on it,
        weet nooit wat er kan gebueren als je inzet heeft. ๐Ÿ˜„
        one crit i have, seeing the name of the picture,
        the d.o.f. is a bit to much on the other tower, at first i thought it was a blurry reflection of the tower, but then realized it's another tower behind. maybe lessen the d.o.f. or remove it completely,
        because of you're style, it would be darker than the front tower making it blend in the darkness.
        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
        Le Corbusier
        • StinkieS Offline
          Stinkie
          Sorry for bumping this thread. Did some tinkering. Used Modo for this. I like it - though it wouldn't have hurt the image if I understood Modo's renderer better. ๐Ÿ˜Ž
          • K Offline
            kwistenbiebel
            Second one is much better (in my humble opinion) Nice ๐Ÿ‘
            • olisheaO Offline
              olishea
              hi stinkie,
              why have u chosen this particular subject? nice render (2nd one) although if u cropped the first one i think it would look better. i like how u can just about see the tower behind, kinda sinister.
              oli
              • artysmediaA Offline
                artysmedia
                I think the first one is too dark to me, but all two are very good buildings! ๐Ÿ‘
                Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                Blog: Artysmedia
                • StinkieS Offline
                  Stinkie
                  Thanks. I agree. But then I would, wouldn't I? ๐Ÿ˜Ž
                  I've had a keen interest in second-rate modernist architecture (and art) since my early teens. No internet prOn, back then. Tough times. On a more serious note: some modernist architecture provides the wannabe De Chirico with all the building blocks he needs. ๐Ÿ˜‰
                  Tried that already, as I didn't want to see hours of rendering go wasted. Still kinda sucked. ๐Ÿ˜„
                  Thanks.
                  • 2 Offline
                    21D
                    nice render mate......one question, what was your workflow from SU 2 Modo?
                    because I am also learning Modo, but importing SU files are a hassle due to the triangulation, so you end up with way to many polygons that you don't need, if it possible to make some kind of tutorial i would apreciate it a lot, seeing that you got a very impresive result out of the SU2MODO procces.
                    again really nice images, as always, can't expect anything less than "great" from you mate ๐Ÿ˜„
                    Le Corbusier
                    • StinkieS Offline
                      Stinkie
                      Thanks.
                      The Luxology forum has a search box. ๐Ÿ˜‰ This looks like a useful thread:
                      http://forums.luxology.com/discussion/topic.aspx?id=35060&show=sketchup
                        CameronVan
                        I like both the images however if the building were not in the center of the frame it would feel more comfortable.
