    Joint Variables
    5 Posts 2 Posters 955 Views 2 Watching
    • N Offline
      NorviewsVeteran
      Can you grab a variable from a joint like using a potentiometer?
      //This_Is_All(I)+=Know()About.Code;
        CPhillips
        If you mean read the actual rotation of a body connected to a joint, no. Not in this version.
        • N Offline
          NorviewsVeteran
          //Maybe have a potentiometer or motor encoder joint in SPIV?
          Is there a way to take a servo's value in order to increase the servo on a key press?
            CPhillips
            Yes.
            in servos controller (not tested)
            @myPos=0.0 if frame==0;@myPos+=0.1 if(key("up"));@myPos
            • N Offline
              NorviewsVeteran
              That particular script sends the servo into a progressive death spin, however the @myPos should prove very useful.
