    Help w/ vray glass settings
    3 Posts 2 Posters 595 Views 2 Watching
    • E Offline
      EDMON242004
      Hi, I have been using sketchup for sometime now, but mostly for initial design stages (sketches), it is my first time to actually render inside sketchup, i would gladly appreciate a suggestion for vray glass setting, here is a render i did but the window glass seems wrong.
      help w/ vray glass setting
      • K Offline
        kwistenbiebel
        Is your glazing a single surface?
        In that case, remove the 'refraction layer'.
        • E Offline
          EDMON242004
          Hello Kwisten,thank you for the info I will try that,
