    CNC Routing
    9 Posts 6 Posters 5.8k Views 6 Watching
      bluecollar
      I am sure this is not a new topic but has anyone tried getting a cnc router to "interpret" their fabulous SU designs into reality. If anyone can offer a simple tanslation from Skp. to Alphacam useable info I would be most gratefull
        mut
        yea i use it all the time.
        have a look at my posts in the gallery, they were all routed on a cnc from a sketchup model.
        my workflow is generally as follows:
        lay the components out flat export to dxf -> into qcad for cleanup (for 2d stuff) -> into cam software.
        tom
        http://www.StairBox.com We make stairs... easy
        • E Offline
          ericschimel
          I use my Sketchup models as well for my CNC machine. I use Cut2D, I just export my models from Sketchup to DXF, and import them to Cut2D, setup my toolpaths, then send it over to Mach 3, and I am making dust!
          -Eric
          http://plugin.sketchthis.net
          Sketchup Kitchen Design Plugin
          Custom Models
            Jim
            These guys have created a 2d foam cutter based on SketchUp and a dremel.
            (www.phlatforum.com)
              bluecollar
              tom
              Thanks Tom I also use this process except that i clean up in Autocad then into CAM. My problem with it is that when one creates the model in the first place it is in 3 dimensions. When we convert back to 2d we discard a third of the information that the router requires ie. depth. Which has to then be reprogrammed, this I have found to be incredibly time consuming and also leads to errors. The solution I hope to find is an export format that keeps all the 3d information.
              I have thus far had limited success exporting STL files but not to the point where I dont end up back at 2D drawings.
              Stephen
                remus
                You might want to have a look at this: http://www.cadspan.com/tools if you havent already.
                I think a lot of the problems associated with exporting .stl files are due to issues with the mesh, and that plugin is meant to help with cleaning up the mesh.
                  mut
                  It all depends what you are machining, if you look in the gallery at 2 of my posts (car audio one and newel cap)
                  they were both done by exporting STL, and then i used a bullnose cutter to machine it, but if you are machining items which are easily viewed in 2d (Stair stringers/treads etc for me) then its way faster to just apply a tool path, and give it a depth.
                  That being said, a lot of what i do is similar over and over again, so after a while you stop making errors etc, maybe if i was doing lots of different things i would have a different outlook. πŸ˜„
                    bluecollar
                    Thanks Remus
                    Have downloaded free trial and give it a go. In principle I think it should work as a 3axis router works in much the same way that as 3d printing machine does (or so I imagine). I will give feedback once I have tried it
                    • G Offline
                      grahamc
                      I do exactly as Mut mentioned and it works every time for me, however I did have some issues in the first couple fo times I did it.
                      Graham
                      CNC wood routing
