    How to set page index?
    7 Posts 2 Posters 520 Views 2 Watching
    • PixeroP Offline
      Pixero
      What is the correct way of setting the index and name with "pages.add" ?
      I want to inset a new page at a certain position.
        Jim
        Jan,
        I haven't tested, but if the new pages gets added after the "current" page, you could set the current page before adding the new page?
        • PixeroP Offline
          Pixero
          I'm not sure that would work in this perticular case.
          The docs says:
          If index is given, it specifies the position in the page list that the new page is added. Otherwise the new page is added to the end.
          name The name of the specific page.
          flags (optional) Bit flags in integer form.
          index (optional) Index of where to inset.
          So if I want to add a page, give it a name AND a index what would be the correct syntax?
          pages.add "name" ??????
          • PixeroP Offline
            Pixero
            Really, no one knows this?
              Jim
              I'm not how to derive the value for the second argument (flags) is used for - 0 works but it's not what you want. I'll need to see if I can find that...
              index = 0
              model = Sketchup.active_model
              pages = model.pages
              pages.add("Page Name", 0, index)
              You may need to go through each page property and set them.
                Jim
                Ok, I found the flags:
                Object.constants.grep /^pag/i
                ["PAGE_USE_SECTION_PLANES", "PAGE_USE_ALL", "PAGE_NO_CAMERA", "PAGE_USE_CAMERA", "PAGE_USE_RENDERING_OPTIONS", "PAGE_USE_SHADOWINFO", "PAGE_USE_SKETCHCS", "PAGE_USE_HIDDEN", "PAGE_USE_LAYER_VISIBILITY"]
                And it looks like PAGE_USE_ALL will do it if you want the default of All Enabled.
                pages = model.pages
                index = 0
                page = pages.add("New Page", PAGE_USE_ALL, index)
                If you want to pick and choose which options, bitwise OR ( | ) the options together:
                pages = model.pages
                index = 0
                page = pages.add("New Page", (PAGE_USE_HIDDEN|PAGE_USE_CAMERA), index)
                • PixeroP Offline
                  Pixero
                  Thanks, will try this.
