⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Possible plugin?
3 Posts 2 Posters 211 Views 2 Watching
  • E Offline
    EscapeArtist
    Is there a plugin that can extrude multiple faces simultaneously and create segments during the extrusion?
    For example, start with a cube or plane. Pick the face and divide it in half, both directions, so you now have a face with 4 equal faces on it. Select all 4 faces (and what I want the plugin to do) and extrude all faces sort of like "joint push pull" but be able to input distance and number of segments or divisions.
    Does it exist?
      remus
      I know fred06's joint push pull can extrude multiple faces, i dont think it does the dividing thing, though.
      How do you think the dividing thing should work on non-uniform shapes?
      • E Offline
        EscapeArtist
        I hadn't thought that far ahead. I was just hoping a plugin existed like joint push pull that could be set with a distance/division modifier.
        I suppose if it were a plugin request it would be pretty much like joint push pull, extrude along the normal or axis of choice with the ability to select distance and number of segments either by "X" distance divided "Y" segments, or, extrude "Y" segments "Z" number of times. What the heck, throw a selection of taper by % or numerical distance amount per segment too, and that would make a fine combination of joint push pull and a little bit of Greeble too.
