    LightUp WIP
    40 Posts 15 Posters 6.0k Views 15 Watching
      sepo
      Still from WIP project. I need to add trees and some other bits. No postprocessing of any kind.
      I am very impressed with this software. It took only 4min to calculate in this case.After that I I can extract any number of stills or have animation or just move in real time.
        silver_shadow
        i really like it, nicely done Sepo
          lucifer1101
          the driveways stood out quite well, where did you get the idea for that?
          i love the design but it could still use a little bit of work..
          Some of my 3d
            sepo
            Thanks guys. The ramps were quite pain to model as the terrain is accurate , made from survey. Yes, need to add lake behind and a lot of trees, couple of cars etc. Wonder how all this will bloom in file size. 😉
            • K Offline
              kwistenbiebel
              Great stuff Sid!
              It is indeed remarkable that it only needs to calculate light once and you can produce an infinite number of images after that.
              This kind of 'real time' rendering definitely is going to be the future.
              • olisheaO Offline
                olishea
                nice work sepo. ive seen light up in use and it looks amazing. definitely the way forward. real time rendering cant be too far off now. again, nice work...im guessing this is three houses you posted on suplugins?
                oli
                  sepo
                  Cheers Chris.
                  Yes Oli this is the update on thehouses. Here is Podium render(done earlier) which sold it to clients.
                  • olisheaO Offline
                    olishea
                    is that radial gradient in background or lighting effects? looks nice
                    oli
                      Roger
                      Where can I find out more about lightup?
                      http://www.azcreative.com
                      • tbdT Offline
                        tbd
                        Official site - http://www.light-up.co.uk/
                        SketchUp Ruby Consultant | Podium 1.x developer
                        http://plugins.ro
                          sepo
                          Oli, it is vignetting.
                            teofas
                            nice done sepo, i like the second image the architecture is good i like it!
                            http://www.spazioarquitectura.com
                            • RichardR Offline
                              Richard
                              Hope you keep us posted with updates mate!
                              BTW can you get a bit more light out of the images straight from rendering?
                              BUILTBRAND.COM.AU
                                sepo
                                Thanks Teo. I will have to try it in Vray as well.
                                  sepo
                                  Richard I think your screen is wee dark 😄 . I was looking your very nice Maxwell render in the forum but to me looks brightness is bit too strong and not enough contrast. Saying that you are in sunny Ozz and I am in UK. 😉
                                  The LightUp image will depend on HDR image you are using. The Second Podium I like the strong contrast. Mind you it maybe not be to everyone taste.
                                  • RichardR Offline
                                    Richard
                                    Mate I think in part you are a bit right! I edited that on my Laptop and just cant seem to get the brightness to match my desktop monitor! Well I can get part of it to match but as soon as you lift or lower your eyeline it is either over or under exposed! Dam HP crap screens!!!
                                    BUILTBRAND.COM.AU
                                      sepo
                                      LightUp 1.5 WIP...Great improvemnet to 1.4
                                      little post process
                                        sepo
                                        No post process
                                        raw
                                        • RichardR Offline
                                          Richard
                                          Man I'm impressed!
                                          Question - in the last images is the HDRI the only lighting? Pretty good if it is!
                                          Well done mate!
                                          BUILTBRAND.COM.AU
                                            sepo
                                            Thanks Richard. It is AO and HDR only lighting . I am very impressed with LightUp as well.Simple to setup and you can create animations, move in rendered environment in real time regardless how big is the SU file and also extract number of images. Here is just another image trying bumps and specular(Onyx tree). LightUp handles transparent .png well and no need for alpha to have correct shadows.
                                            • 1 / 2
