    Help with hyperlinks
    10 Posts 4 Posters 9.8k Views 4 Watching
    • V
      VisionM
      Hi all
      I have used SU for some years now and have always been very appreciative of the help I find freely given in the forums. This is the first time I've asked for help so here goes...............
      I have a project to model a site of 19 hectares and am trying to plan my approach first, being very aware of the potential size of this model. The site includes commercial and residential buildings plus a lake, native tree stand and various landscaping features. What I'm planning to do is a 'sketchy' outline model of the whole site showing the differing zones - this should be low poly enough to orbit etc. Then I would like to attach hyperlinks to certain components that would open up a more detailed SU file for that particular aspect. I will then render selected images from each detailed SU model.
      Is it possible to link from SU file to SU file from hyperlinks? I'm guessing this would require a ruby script but although I use them I can't write them.
      I would be very grateful if any of you experts could guide me in the right direction and offer some suggestions?
      Thank you very much.
      Lesley
      • R
        remus
        Im not sure if it is possible, but it would certainly be a great plugin if it was.
        • H
          HPW
          Link from local file to local file?
          Or link to an url with the file?
          One hyperlink per component?
          Some rough ideas (WIN):
          For an local file the idea is to write a ruby script with a 'require Win32API.so' and import the ShellExecute from shell32.dll .
          The hyperlink could be stored in a DC-attribut:
          sel_def.set_attribute 'dynamic_attributes', 'hyperlink', 'c:....'
          sel_def.set_attribute 'dynamic_attributes', 'hyperlink2', 'c:....'
          A ruby command would read the attribut and fire the ShellExecute.
          Of cource a second instance of sketchup will start.
          For an external URL no idea yet.
          It would need to first download it and then open it in a second instance.
          • V
            VisionM
            Hi HPW
            I was thinking of local file to local file so that it could be displayed either by myself in a presentation or put on a CD using the viewer. Thanks for your suggestions - I'm not sure how to implement your suggestion but I do know someone who can write Ruby scripts so may get some help there. Sounds like it could be possible? I don't think starting a second instance would necessarily be a problem if I was controlling it....
            • H
              HPW
              For interfacing Win32API your ruby-scripter may have a look at Jim's toggleWindows.rb
              • AdamBA
                AdamB
                Here you go. Put this in your Plugins folder and restart SU.
                Now you can right click over a Group and either Set the file to link to, or Open an already set link.
                Enjoy,
                Adam
                linkfile.rb
                • V
                  VisionM
                  Hi Adam
                  Thanks so much - I really appreciate your time doing that - it works well. I can now plan how to tackle the rest of the project in my sleep as its 10pm at night here in New Zealand.
                  Cheers
                  Lesley
                  • V
                    VisionM
                    Hi HPW - where can I find Jim's toggleWindow script? I've searched but no luck?
                    • H
                      HPW
                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18006&start=0&st=0&sk=t&sd=a
                      • H
                        HPW
                        Adam,
                        Thanks for the script.
                        I wasn't aware of Sketchup.open_file(url).
                        Does it open a new instance or does it replace the open file?
