    Flags on onKeyDown?
    21 Posts 8 Posters 2.8k Views 8 Watching
      Jim
      @chris fullmer said:
      I don't quite understand what that means. What is bitwise?
      Think in binary, then compare them column for column. It's a logical, bit-to-bit comparison.
      5 in binary is 101
      6 in binary is 110
      5 & 6 is; logical AND each column (bit position)
          Columns
      ________________
      |  1  |  0  |  1   <- decimal 5
      | and | and | and
      |  1  |  1  |  0   <- decimal 6
         1     0     0
      so 101 & 110 = 100 <- decimal 4
      The masks are constants, which are set to some convenient values:
      # I just made these up
      001 = CONSTRAIN_MASK
      010 = ALT_MASK
      100 = COPY_MASK
      So if the flag is decimal value 7:
      111  <- decimal 7
      In order to check the CONSTRAIN_MASK, you logical AND the CONSTRAIN_MASK with the flag value:
          111  <- flag value decimal 7
        & 001  <- contain mask constant
          001 <- CONSTRAIN_MASK set true
      or in real ruby as Thomas wrote;
      contrain_key_down = ((flags & CONSTRAIN_MODIFIER_MASK) == CONSTRAIN_MODIFIER_MASK)
      copy_key_down = ((flags & COPY_MODIFIER_MASK) == COPY_MODIFIER_MASK)
      alt_key_down = ((flags & ALT_MODIFIER_MASK) == ALT_MODIFIER_MASK)
      Although Adam B might know a clever way to decode them all in one elegant statement.
      • 2 / 2
