    Interior-Vray4Sketchup test
    13 Posts 8 Posters 1.0k Views 8 Watching
    • cucsat2003C Offline
      cucsat2003
      This is not my design,I just used the model for Vray4Sketchup-test.render time:34mins
      Wish your all comment!!!
      http://i298.photobucket.com/albums/mm249/cucsat2003/3copy-1.jpg
      • G Offline
        GdBTM
        wow!
        did you use sketchup's materials?
        can you post the model?
          liam887
          wow thats nice, are those textures applied in sketchup? have you touched the render up afterwards? Can you post some more details please?
          VISIT MY ONLINE GALLERY
            sepo
            That scene looks same like Nomer's scene. BTW you should go easy on a floor bumps. You can trip over πŸ˜‰
            • marked001M Offline
              marked001
              definitley really nice....like sepo said, a little crazy on the floor bump... and maybe adjust the glass material or something so the table doesnt disappear?
              http://www.revision21vis.com
              instagram: revi21on
                cucsat2003
                thank you for comments!^^
                yes,I used sketchup materials for all details.
                I also feel the problem with bump in floor and glass vismat πŸ’š
                and this is the model:http://www.mediafire.com/?sharekey=f4b8c3473791ab5b07258ee67c679e4ae04e75f6e8ebb871
                  Joker90
                  I can't open this link. Maybe you have mistyped it, could you check? I really like this scene....
                    sepo
                    Just copy the link in your browser
                      Joker90
                      I did that, I am that able... But, at first the page seemed as if it doesn't exists and after a while I tried to open it again and got the notification "0 items found to display!". (tried to switch browsers too)
                        teofas
                        hi cucsat, the render is good, but there are some things that can be improve...the floor bump its too much,,,the carpet or rug needs more work try to play with the displacement parameters on your options,,,the dark areas are too dark, maybe you can use a rect light like some kind of backup light, cause its really dark, the material on the eames chair its really good,,we will be waiting for an update!
                        http://www.spazioarquitectura.com
                        • N Offline
                          nomeradona
                          @cucsat, next time before you share the model you need to asked permission if is ok to share the model as it could have some issue with the original modeller.
                          visit my blog: http://www.nomeradona.blogspot.com
                          • N Offline
                            nomeradona
                            yeap! in line with sketchucation render challenges, i asked nguoithoiken to share this model for a localized vietnamese render challenge. and i guess skethcucation can have the same challenge (but let me asked him, i know this dude wont mine). but if you are using the model be sure to removed the materials on top of the group as vray will have difficulty in parsing the geometry. of course podium and hypershot wont.
                              cucsat2003
                              thanks Nomer brother for reminder!I made mistake,Ill remember this rule.
                              Ill ask nguoithoiken to share this model.thank you again!
