    Sketchup, podium and photomatix
    26 Posts 7 Posters 9.8k Views 7 Watching
    • N
      nomeradona
      i am looking on post processing my images in HDRI. since podium is quick in rendering why not try rendering 3 different exposures and use my photomatix to process my image and create my hdri... of course my final output was saved as jpeg for posting reason. the good thing in photomatix is you have a lot of options.
      here is my first try with thoikens interior. i think not so bad except for some burnout. but i think since this is my forst try its forgiveable. will look on other xml setting to correct the burnout.
      please let me know your feedback..
      http://i334.photobucket.com/albums/m421/nomeradona_1234/Podiumhdri.jpg
      visit my blog: http://www.nomeradona.blogspot.com
      • S
        sepo
        Saw it on Podium forum....Looks quite good. I supose different xml could be also used for varied output.
        • N
          nomeradona
          that is actually my second one.
          • S
            sepo
            Right.....they look quite similar (same ) to me.
            • N
              nomeradona
              oops sorry, i mean that would be my second test. i used optimalem xml for the three and just adjusted the dark slider. but the next one im doing is using different xml since i want to rid of the burn out.
              • T
                teofas
                well done nomer, that photomatix soft is like photoshop?
                http://www.spazioarquitectura.com
                • N
                  nomeradona
                  hi teofas, photomatix is an hdri shop. although we could also use photoshop to do an hdri image, imho photomatix is better when it comes to hdri.
                  so photoshop is broader when it comes to post processin images. photomatix is only for hugh dynamic range images. i was actually using it for my students in photography and also im using it when it comes to doing my environment in hypershot render enviroment.
                  • T
                    teofas
                    thx for the reply nomer!
                    • N
                      nomeradona
                      your welcome bro.
                      to understand further the workflow i would like to post here the original podium render before i load them to photomatix. I actually use my photomatix to create HDRI and i just thought why not use it using rendered image and see how. fair enough, i think its one way how to explore further this area with SU, rendered image and photomatix as post processing software.
                      here are my three raw podium output. btw im testing the beta(unrelease)of podium and testing blurry reflection
                      http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410174742_12m41s.jpg
                      http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410164719_12m12s.jpg
                      http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410180930_12m23s.jpg
                      what i did is i reloaded the three images in photomatix by clicking create hdri. then the rest is up to you when you are adjusting the various sliders in Tone Mapping.
                      • G
                        GdBTM
                        fantastic renders...compliments!
                        • N
                          nomeradona
                          thanks gdb that you like them.
                          • G
                            GdBTM
                            it looks real! ๐Ÿ˜ฎ
                            • soloS
                              solo
                              Whoa!!! Nomer that Vray render rocks!!!
                              I kinda feel bad for Podium on this one.
                              Excellent render, and nice floor mat, can I enquire where you got it? as I am in need of some good wood and tile floor mats.
                              http://www.solos-art.com
                              • FrederikF
                                Frederik
                                @solo said:
                                ...can I enquire where you got it? as I am in need of some good wood and tile floor mats.
                                Not sure where Normer got his floor material from, but I can certainly recommend that you visit Arroway Textures...
                                They have a very nice range of wooden floor materials with diffuse-, bump- and reflectivity-maps... ๐Ÿ˜‰
                                Cheers
                                Kim Frederik
                                • soloS
                                  solo
                                  I have seen those, even downloaded some low rez ones, but yikes!! they are pricey.
                                  • FrederikF
                                    Frederik
                                    You're welcome... ๐Ÿ˜
                                    Perhaps you can then find some from CG Textures...
                                    They don't come along with bump- and relection-maps, but you should be able to make these yourself from the diffuse-map image...
                                    Cheers
                                    Kim Frederik
                                    • soloS
                                      solo
                                      You're welcome...
                                      Sorry mate, I do appreciate the reply ๐Ÿ˜„ .
                                      Maybe I'm a little grouchy (sp) today, as yesterday I killed my main work rig, I believe it had something to do with static so I'm down to dual cores at moment and that really sucks in the rendering department, but faster with SU.
                                      • N
                                        nomeradona
                                        it looks real! ๐Ÿ˜ฎ
                                        thanks ๐Ÿ˜„
                                        • FrederikF
                                          Frederik
                                          No need to apologize... I just couldn't resist teasing you a bit... ๐Ÿ˜„
                                          I'm sorry to hear about your quad system... Hopefully you'll find a new rig soon...?!
                                          Cheers
                                          Kim Frederik
                                          • soloS
                                            solo
                                            Nomeradona wrote:
                                            my apology. i just want to put the same model in one thread.
                                            No need for an opology mate, I was just remarking that the vray render is so good that any render would look bland against it. ๐Ÿ‘
                                            • 1 / 2
