    Sketchup, podium and photomatix
    26 Posts 7 Posters 9.9k Views 7 Watching
    • N
      nomeradona
      @sepo said:
      Saw it on Podium forum....Looks quite good. I supose different xml could be also used for varied output.
      that is actually my second one.
        sepo
        Right.....they look quite similar (same ) to me.
        • N
          nomeradona
          oops sorry, i mean that would be my second test. i used optimalem xml for the three and just adjusted the dark slider. but the next one im doing is using different xml since i want to rid of the burn out.
          • T
            teofas
            well done nomer, that photomatix soft is like photoshop?
            http://www.spazioarquitectura.com
            • N
              nomeradona
              hi teofas, photomatix is an hdri shop. although we could also use photoshop to do an hdri image, imho photomatix is better when it comes to hdri.
              so photoshop is broader when it comes to post processin images. photomatix is only for hugh dynamic range images. i was actually using it for my students in photography and also im using it when it comes to doing my environment in hypershot render enviroment.
              • T
                teofas
                thx for the reply nomer!
                • N
                  nomeradona
                  your welcome bro.
                  to understand further the workflow i would like to post here the original podium render before i load them to photomatix. I actually use my photomatix to create HDRI and i just thought why not use it using rendered image and see how. fair enough, i think its one way how to explore further this area with SU, rendered image and photomatix as post processing software.
                  here are my three raw podium output. btw im testing the beta(unrelease)of podium and testing blurry reflection
                  http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410174742_12m41s.jpg
                  http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410164719_12m12s.jpg
                  http://i334.photobucket.com/albums/m421/nomeradona_1234/20090410180930_12m23s.jpg
                  what i did is i reloaded the three images in photomatix by clicking create hdri. then the rest is up to you when you are adjusting the various sliders in Tone Mapping.
                  • G
                    GdBTM
                    fantastic renders...compliments!
                    • N
                      nomeradona
                      thanks gdb that you like them.
                      • G
                        GdBTM
                        it looks real! ๐Ÿ˜ฎ
                        • soloS
                          Whoa!!! Nomer that Vray render rocks!!!
                          I kinda feel bad for Podium on this one.
                          Excellent render, and nice floor mat, can I enquire where you got it? as I am in need of some good wood and tile floor mats.
                          • FrederikF
                            Frederik
                            @solo said:
                            ...can I enquire where you got it? as I am in need of some good wood and tile floor mats.
                            Not sure where Normer got his floor material from, but I can certainly recommend that you visit Arroway Textures...
                            They have a very nice range of wooden floor materials with diffuse-, bump- and reflectivity-maps... ๐Ÿ˜‰
                            Cheers
                            Kim Frederik
                            • soloS
                              I have seen those, even downloaded some low rez ones, but yikes!! they are pricey.
                              • FrederikF
                                Frederik
                                You're welcome... ๐Ÿ˜
                                Perhaps you can then find some from CG Textures...
                                They don't come along with bump- and relection-maps, but you should be able to make these yourself from the diffuse-map image...
                                Cheers
                                Kim Frederik
                                • soloS
                                  You're welcome...
                                  Sorry mate, I do appreciate the reply ๐Ÿ˜„ .
                                  Maybe I'm a little grouchy (sp) today, as yesterday I killed my main work rig, I believe it had something to do with static so I'm down to dual cores at moment and that really sucks in the rendering department, but faster with SU.
                                  • N
                                    nomeradona
                                    it looks real! ๐Ÿ˜ฎ
                                    thanks ๐Ÿ˜„
                                    • FrederikF
                                      Frederik
                                      No need to apologize... I just couldn't resist teasing you a bit... ๐Ÿ˜„
                                      I'm sorry to hear about your quad system... Hopefully you'll find a new rig soon...?!
                                      Cheers
                                      Kim Frederik
                                      • soloS
                                        Nomeradona wrote:
                                        my apology. i just want to put the same model in one thread.
                                        No need for an opology mate, I was just remarking that the vray render is so good that any render would look bland against it. ๐Ÿ‘
                                        • N
                                          nomeradona
                                          oh ok.. ๐Ÿ˜„
                                          • N
                                            nomeradona
                                            HYPERSHOT render
                                            http://i334.photobucket.com/albums/m421/nomeradona_1234/hypershotrender.jpg
