    Color Sensor
    5 Posts 3 Posters 715 Views 3 Watching
    • P Offline
      Physicsguy1
      I highly doubt it is possible, but i would love to see a color sensor. One that outputs a variable depending on the color. maybe it could sense the object color beneath the object?
      • P Offline
        Physicsguy1
        Here is an example of what i want it to do, without the complicated mechanics behind the movement.
        example.skp
        • MALAISEM Offline
          MALAISE
          Hi =Physicsguy= 👍
          Color sensor's idea is very interesting. I had suggested a similar idea using a mechanical sensor (switch). The question is: how to read this sensor information and link it to drive motor, hinge.... ?
          Ps: may be a full colour spectrum ( I mean RGB coding) could be used, we could see the box rotates according
          a colour's law angle. Black : 0, full White :255 -> 90°.
          MALAISE
            CPhillips
            Color detection probably isnt going to happen. But it is possible that (in a future version) you could tag an object as "red" or whatever and then do something based on that color.
            So in your example you could put a nocollison cube on the bottom. Then if it was touching the black or white squares the onTouch could do something.
              CPhillips
              @malaise said:
              Hi =Physicsguy= 👍
              MALAISE
              Mechanical sensors are now possible if you use an object with an onTouch field.
