    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Evermotion rendering competition - my version WIP
    10 Posts 6 Posters 1.1k Views 6 Watching
      rcossoli
      Hi people this is the picture I'm doing for the competition which was organized evermotion rendering, is the first serious version of my image with the textures (even though all need to adjust) the camera position and almost end lighting.
      it is clear that the image has nothing to photoshop as competition asked not to be touched in any program (photoshop or similar) in order to see the true performance of each engine, just looking at the page I found evermotion many gave the same suggestion.
      greetings
      render kerkythea Nยบ 17 method, time 2 hours and 20 minutes more or les original size 2000x1200 px
      competition link
      my inglish is: ๐Ÿ˜ž
      THREEDIMENSIONSWEB dot COM
      • soloS Offline
        solo
        Cool render.
        I had a look at the file, it converts to about 8MB ๐Ÿ˜ฎ , a little steep for use in SU, especially if one plans to use additional models and photo textures.
        http://www.solos-art.com
          rcossoli
          The palm tree is a model from you pete
          if something heavy like the file is empty, but it can work, is not so complicated
          thanks for the comment and the palm ๐Ÿ˜‰
            rcossoli
            New pic...
            C&C are welcome!
              sepo
              Looks good...a bit of bump on water as water is never still.
                teofas
                hi ricardo, very nice image, i agree with sepo some bump on water, but to me its looking good bro!!
                http://www.spazioarquitectura.com
                • FrederikF Offline
                  Frederik
                  Looking really good, rcossoli... ๐Ÿ‘
                  But like others before me have said, a subtle bump on the water material, will make this render even more convincing... ๐Ÿ˜‰
                  Or you can use Sqirlz Water Reflections to create some in post pro...
                  Here's a quick flash example I just made... ๐Ÿ˜‰
                  (If you right-click and select Loop and Play, you'll see the animation...)
                  [flash=560,336:2w8ucbvu]http://www.kerkythea.net/users/Frederik/rcossoli-evermotion6a.swf[/flash:2w8ucbvu]
                  Cheers
                  Kim Frederik
                    rcossoli
                    thanks for the comments Sepo and teofas
                    Tahnks!! frederick in this competition, unfortunately nothing can be done post production, so I suggest to see the results as they leave the program rendering
                    but just thank you very much for the trick is to keep in mind ๐Ÿ‘
                      teofas
                      wow frederik very nice trick!
                      • free agentF Offline
                        free agent
                        i have a pool that would dissagree with you there, however it is generally accepted that a bump makes it look more like water...
