    Wine & water glasses
    6 Posts 4 Posters 847 Views 4 Watching
    • E Offline
      Eulgrand
      Hi all,
      Entering my "glassware" period ! I know, this kind of glass should be filled with Champagne...
      SU6 + Kerkythea 2008 Echo - MLT(BPT) / 160 passes / DOF : post-pro
      • boofredlayB Offline
        boofredlay
        Wow, very well done.
        • MALAISEM Offline
          MALAISE
          Eulgrand, il est trouble ton vin rouge. 😆 👍 👍
          MALAISE
          • E Offline
            Eulgrand
            Fond de bouteille...
            Cela dit, c'est une très bonne remarque : il y a un peu de Fall-off (0.05) dans le matériau 😉
            • Jean-FrancoJ Offline
              Jean-Franco
              Hi All,
              Eulgrand, very, very nice indeed ! How long did it take to achieve this result ?
              I'm not asking for rendering time, but for preparation and trails.
              Jean-Franco
              • E Offline
                Eulgrand
                Thank you Jean-Franco,
                If I had to do it once again from scratch, I would say no more than 30 minutes. The modeling has nothing complicated, the time-consuming part is drawing a nice shape using Bezier curves. Once this is done, you just have to "follow-me" around a 48 segments circle, detach the part witch will be the interface between the glass & content, model the meniscus, and that's all. The process is nicely described in this tutorial by Patrick Nieborg.
