    Position of a point
    4 Posts 2 Posters 361 Views 2 Watching
      Matt666
      Hi all!
      Answer is certainly easy, but I don't know how to do...
      I want to find position of a point, determining by :
      • Position of an initial point
      • Distance
      • Vector
        How can I find this point? πŸ˜‰
      Frenglish at its best !
      My scripts
        Matt666
        Ah great!! It works perfectly! vector.length.... I didn't aware of that!
        Thank you Chris!
        My scripts
        • Chris FullmerC Offline
          use point.offset
          point1 = (the known point position) vector = (the known vector position) distance = (the known distasnce) vector.length = distance point2 = point1.offset vector
          That will then give you point2 as the new point. The vector.length = distance line sets the known vector to the desired length - you can skip it if you know that your vector is already set to the correct length. Hope that helps,
          Chris
          All my Plugins I've written
            Excellent, glad it helped (and worked). I also just edited a minor typo in the example, but I'm sure you figured it out even with the typo,
            Chris
