    Layout 2 scriptable with Ruby?
    4 Posts 3 Posters 468 Views 3 Watching
    • H Offline
      HPW
      Hello,
      In Autocad I can script the layout and plot process with autolisp.
      So is it possible to make layouts in Layout 2 automaticly with ruby and plot the result?
      Regards
      Hans-Peter
        remus
        No, theres isnt a ruby api for layout (unless someone slipped it in there while i wasnt watching.)
        You could always draw your plan in SU (using some scripts if you need to) and import it in to layout. Wouldnt behave like a native layout object though πŸ˜‰
          jhauswirth
          Can you give some examples of what you script so we can get some ideas of what to add to a scripting interface?
          • H Offline
            HPW
            I am not familar with Layout and it capabilitys since I am evaluating the specs for a possible future use.
            When I undertstand it right Layout is a separte EXE/Modul and not running in the same process then SketchUp.
            In Autocad the modellviews in modellspace are similar to the modellviews in paperspace.
            Both can be reached from autolisp and automated/scripted.
            So what I would expect from scripting layout:
            Inserting forms/templates and filling their data-fields.
            Drawing primitives (lines,arrows,text and whatever layout supports) in Paperspace
            Placing views and set them up with view-points, camera-settings, rendermodes etc.
            Iterating (reading propertys) through all elements in paperspace.
            Interfacing with the SketchUp main-modul. (Starting a layout/print process in Sketchup/Ruby, doing the job (passing a ruby call to layout) in layout/Ruby and return back to the calling point in SketchUp)
            Control (filenames/printers) the output (Printing/Exporting) with Ruby in Layout.
            So be able to give a customer a cadalog with Sketchup Components and ready made forms/templates and custom ruby code/toolbars to allow him easy product customising.
            (I hope I make it clear so far, since I am not native english)
            Greetings from germany
            Regards
            Hans-Peter
